[SCM] PostGIS branch master updated. 3.5.0-21-g77bcee793
git at osgeo.org
git at osgeo.org
Fri Oct 11 23:39:02 PDT 2024
the project "PostGIS".
via 77bcee79332a82a5b5fc7ae6ae47470939a855fa (commit)
from f266d62c1e209c4544ab44eeb149ebe951cd4064 (commit)
revisions in full, below.
commit 77bcee79332a82a5b5fc7ae6ae47470939a855fa
Author: Maxime Schoemans <maxime.schoemans at ulb.ac.be>
Date: Fri Sep 27 18:27:01 2024 +0200
export circ_tree_distance_tree_internal
and use memset instead of bzero
Closes #5784 for PostGIS 3.6.0
diff --git a/NEWS b/NEWS
index 4a66a90f3..e035f6c71 100644
--- a/NEWS
+++ b/NEWS
@@ -8,3 +8,6 @@ PostGIS 3.6.0
* New Features *
+#5784, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use
+ (Maxime Schoemans)
diff --git a/liblwgeom/lwgeodetic_tree.c b/liblwgeom/lwgeodetic_tree.c
index 6e7909741..7031df4be 100644
--- a/liblwgeom/lwgeodetic_tree.c
+++ b/liblwgeom/lwgeodetic_tree.c
@@ -30,7 +30,6 @@
/* Internal prototype */
static CIRC_NODE* circ_nodes_merge(CIRC_NODE** nodes, int num_nodes);
-static double circ_tree_distance_tree_internal(const CIRC_NODE* n1, const CIRC_NODE* n2, double threshold, double* min_dist, double* max_dist, GEOGRAPHIC_POINT* closest1, GEOGRAPHIC_POINT* closest2);
diff --git a/liblwgeom/lwgeodetic_tree.h b/liblwgeom/lwgeodetic_tree.h
index 90987a6cf..bf025566f 100644
--- a/liblwgeom/lwgeodetic_tree.h
+++ b/liblwgeom/lwgeodetic_tree.h
@@ -52,6 +52,7 @@ CIRC_NODE* circ_tree_new(const POINTARRAY* pa);
void circ_tree_free(CIRC_NODE* node);
int circ_tree_contains_point(const CIRC_NODE* node, const POINT2D* pt, const POINT2D* pt_outside, int level, int* on_boundary);
double circ_tree_distance_tree(const CIRC_NODE* n1, const CIRC_NODE* n2, const SPHEROID *spheroid, double threshold);
+double circ_tree_distance_tree_internal(const CIRC_NODE* n1, const CIRC_NODE* n2, double threshold, double* min_dist, double* max_dist, GEOGRAPHIC_POINT* closest1, GEOGRAPHIC_POINT* closest2);
CIRC_NODE* lwgeom_calculate_circ_tree(const LWGEOM* lwgeom);
int circ_tree_get_point(const CIRC_NODE* node, POINT2D* pt);
int circ_tree_get_point_outside(const CIRC_NODE* node, POINT2D* pt);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 3732ed9cc..cabf679a9 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -2219,7 +2219,7 @@ ptarray_scroll_in_place(POINTARRAY *pa, const POINT4D *pt)
/* TODO: reduce allocations */
tmp = ptarray_construct(FLAGS_GET_Z(pa->flags), FLAGS_GET_M(pa->flags), pa->npoints);
- bzero(getPoint_internal(tmp, 0), (size_t)ptsize * pa->npoints);
+ memset(getPoint_internal(tmp, 0), 0, (size_t)ptsize * pa->npoints);
/* Copy the block from found point to last point into the output array */
memcpy(
Summary of changes:
NEWS | 3 +++
liblwgeom/lwgeodetic_tree.c | 1 -
liblwgeom/lwgeodetic_tree.h | 1 +
liblwgeom/ptarray.c | 2 +-
4 files changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
