[PostGIS] #5798: Out of memory: Killed process
trac at osgeo.org
Wed Oct 16 00:57:14 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.4.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
We started at
2024-10-16 06:48:55.150 CEST >LOG: starting PostgreSQL 16.4 (Ubuntu
16.4-1.pgdg22.04+1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
It failed around 4 hours later, setting overcommit to 2 and reduce threads
did not help.
NOTICE: Start create with transfer_method_from_temp_2_final_topology 3
for has_edges_temp_table_name tmp_dyrkbarjord_10_c3_037.edge_data_tmp_1224
at 2024-10-16 09:40:19.671996+02 used_time: 0.448377
NOTICE: Done create with transfer_method_from_temp_2_final_topology 3 for
has_edges_temp_table_name tmp_dyrkbarjord_10_c3_037.edge_data_tmp_1224 at
2024-10-16 09:40:20.179359+02 used_time: 0.506995
NOTICE: Done adding lines 1213 (edges 18327) of 1319, and done ANALYZE
for tmp_dyrkbarjord_10_c3_037_1174 .
NOTICE: start to map face 3 for has_edges_temp_table_name
tmp_dyrkbarjord_10_c3_037.edge_data_tmp_1224 at 2024-10-16
09:40:20.807004+02 used_time: 0.506995
TopMemoryContext: 282504 total in 8 blocks; 10184 free (21 chunks); 272320
used
TopTransactionContext: 8192 total in 1 blocks; 6696 free (1 chunks);
1496 used
Attopt cache: 16384 total in 2 blocks; 6672 free (3 chunks); 9712 used
TableSpace cache: 8192 total in 1 blocks; 2128 free (0 chunks); 6064
used
Type information cache: 24368 total in 2 blocks; 2648 free (0 chunks);
21720 used
TOAST to main relid map: 262144 total in 6 blocks; 38864 free (23
chunks); 223280 used
Autovacuum worker: 131072 total in 5 blocks; 56328 free (17 chunks);
74744 used
Autovacuum Portal: 8192 total in 1 blocks; 7744 free (0 chunks); 448
used
Vacuum: 8192 total in 1 blocks; 7784 free (0 chunks); 408 used
Operator class cache: 8192 total in 1 blocks; 592 free (0 chunks); 7600
used
smgr relation table: 32768 total in 3 blocks; 16880 free (8 chunks);
15888 used
PgStat Pending: 24576 total in 6 blocks; 4048 free (13 chunks); 20528
used
TransactionAbortContext: 32768 total in 1 blocks; 32504 free (0 chunks);
264 used
Portal hash: 8192 total in 1 blocks; 592 free (0 chunks); 7600 used
TopPortalContext: 8192 total in 1 blocks; 7928 free (0 chunks); 264 used
Relcache by OID: 16384 total in 2 blocks; 3584 free (2 chunks); 12800
used
CacheMemoryContext: 1048576 total in 8 blocks; 585048 free (94 chunks);
463528 used
index info: 2048 total in 2 blocks; 616 free (1 chunks); 1432 used:
pg_attrdef_adrelid_adnum_index
index info: 2048 total in 2 blocks; 912 free (0 chunks); 1136 used:
pg_namespace_oid_index
pg_index_indrelid_index
index info: 2048 total in 2 blocks; 544 free (1 chunks); 1504 used:
pg_toast_2619_index
index info: 3072 total in 2 blocks; 912 free (1 chunks); 2160 used:
pg_statistic_relid_att_inh_index
index info: 3072 total in 2 blocks; 1088 free (1 chunks); 1984 used:
pg_amop_opr_fam_index
pg_tablespace_oid_index
index info: 1024 total in 1 blocks; 0 free (0 chunks); 1024 used:
pg_statistic_ext_relid_index
pg_operator_oid_index
index info: 3072 total in 2 blocks; 808 free (1 chunks); 2264 used:
pg_amop_fam_strat_index
pg_cast_source_target_index
pg_opclass_am_name_nsp_index
pg_type_oid_index
pg_index_indexrelid_index
pg_opclass_oid_index
index info: 2048 total in 2 blocks; 544 free (2 chunks); 1504 used:
pg_trigger_tgrelid_tgname_index
index info: 2048 total in 2 blocks; 616 free (3 chunks); 1432 used:
pg_rewrite_rel_rulename_index
pg_class_oid_index
pg_attribute_relid_attnum_index
index info: 3072 total in 2 blocks; 808 free (3 chunks); 2264 used:
pg_amproc_fam_proc_index
pg_authid_oid_index
index info: 3072 total in 2 blocks; 1200 free (3 chunks); 1872 used:
pg_auth_members_member_role_index
index info: 3072 total in 2 blocks; 1232 free (3 chunks); 1840 used:
pg_shseclabel_object_index
index info: 1024 total in 1 blocks; 72 free (0 chunks); 952 used:
pg_database_datname_index
pg_database_oid_index
pg_authid_rolname_index
PgStat Shared Ref Hash: 7216 total in 2 blocks; 688 free (0 chunks);
6528 used
PgStat Shared Ref: 16384 total in 5 blocks; 4296 free (5 chunks); 12088
used
WAL record construction: 50200 total in 2 blocks; 6376 free (0 chunks);
43824 used
PrivateRefCount: 8192 total in 1 blocks; 2648 free (0 chunks); 5544 used
MdSmgr: 8192 total in 1 blocks; 7200 free (17 chunks); 992 used
LOCALLOCK hash: 8192 total in 1 blocks; 592 free (0 chunks); 7600 used
GUCMemoryContext: 24576 total in 2 blocks; 7952 free (9 chunks); 16624
used
GUC hash table: 32768 total in 3 blocks; 12704 free (5 chunks); 20064
used
Timezones: 104112 total in 2 blocks; 2648 free (0 chunks); 101464 used
Postmaster: 16384 total in 2 blocks; 13712 free (15 chunks); 2672 used
ident parser context: 1024 total in 1 blocks; 760 free (0 chunks); 264
used
hba parser context: 50176 total in 9 blocks; 7824 free (12 chunks);
42352 used
ErrorContext: 8192 total in 1 blocks; 7928 free (4 chunks); 264 used
Grand total: 2321840 bytes in 131 blocks; 885360 free (272 chunks);
1436480 used
< , , , 2024-10-16 09:40:22.693 CEST >ERROR: out of memory
< , , , 2024-10-16 09:40:22.693 CEST >DETAIL: Failed on request of size
1073741822 in memory context "TopTransactionContext".
< , , , 2024-10-16 09:40:22.693 CEST >CONTEXT: automatic vacuum of table
"rog_02.pg_toast.pg_toast_2619"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5798#comment:2>
