[PostGIS] #5798: Out of memory: Killed process
trac at osgeo.org
Wed Oct 16 00:38:23 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.4.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
I have now set vm.overcommit_memory=2 and run test with only 100 workes
and it still seems like free memory is steadly falling.
In this run we create around 1300 topologies with more 65. million edges
and more than 3.5 million faces generted from 7 different simple feature
input tables. Each of this 1300 topologies are cleaned up by removing
faces below 10 m2 . We then reduce the number edges to around 5 millon
edges and faces down to below 1 million faces, before it’s moved into
single a topology.
When started free memory was around 100 GB. We are now done with 1250 of
the temp toplogies and free memory is now
Wed Oct 16 09:35:28 CEST 2024
total used free shared buff/cache
available
Mem: 125Gi 57Gi 30Gi 8.3Gi 37Gi
58Gi
Swap: 7.8Gi 259Mi 7.6Gi
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5798#comment:1>
