[PostGIS] #5798: Out of memory: Killed process
PostGIS trac at osgeo.org
Tue Oct 15 21:26:35 PDT 2024
 Reporter:  Lars Aksel Opsahl  |      Owner:  strk
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.5.1
Component:  topology           |    Version:  3.4.x
 Keywords:                     |
 I got a new memory error when using Postgis Toplogy now. Have never seen
 this error before. I am running 100 threads in parallel and some hours I
 get this error.
 Oct 16 00:20:05 cpu11 kernel: [1644367.115588] oom-
 kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0-1,global_oom,task_memcg=/system.slice
 /system-
 postgresql.slice/postgresql at 16-main.service,task=postgres,pid=662537,uid=133
 Oct 16 00:20:05 cpu11 kernel: [1644367.115610] Out of memory: Killed
 process 662537 (postgres) total-vm:8780856kB, anon-rss:7860kB, file-
 rss:444kB, shmem-rss:8041096kB, UID:133 pgtables:16928kB oom_score_adj:0
 Oct 16 00:20:08 cpu11 systemd[1]: postgresql at 16-main.service: Failed with
 result 'oom-kill'.
 Oct 16 00:20:08 cpu11 systemd[1]: postgresql at 16-main.service: Consumed 1w
 14h 21min 45.086s CPU time.
 This problem is present at both this two configs
 POSTGIS="3.6.0dev 3.5.0-16-g4fcfd0fd6" [EXTENSION] PGSQL="160"
 GEOS="3.13.0beta2-CAPI-1.19.0" PROJ="9.3.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ
 9.13.0) LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" TOPOLOGY
 POSTGIS="3.6.0dev 3.5.0-22-g224839693" [EXTENSION] PGSQL="160"
 I am now running a new test and I have also
 sysctl -w vm.overcommit_memory=2
 And I do see that memory is gradually eaten up
 Wed Oct 16 05:44:46 CEST 2024
                total        used        free      shared  buff/cache
 available
 Mem:           125Gi        20Gi        93Gi       3.3Gi        12Gi
 100Gi
 Swap:          7.8Gi       263Mi       7.6Gi
 Wed Oct 16 05:49:54 CEST 2024
 available
 Mem:           125Gi        22Gi        88Gi       3.7Gi        14Gi
 98Gi
 ubuntu, root at cpu11:~#
 Wed Oct 16 06:09:01 CEST 2024
 available
 Mem:           125Gi        22Gi        79Gi       5.7Gi        23Gi
 96Gi
 Swap:          7.8Gi       262Mi       7.6Gi
 Wed Oct 16 06:25:38 CEST 2024
 available
 Mem:           125Gi        22Gi        77Gi       7.0Gi        25Gi
 94Gi
 Here is the complete log from syslog from the last log.
 Oct 16 00:20:05 cpu11 kernel: [1644367.114868] [ 662535]   133 662535
 2192613    56684   700416      458          -900 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114871] [ 662536]   133 662536
 18641      435   126976      472             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114874] [ 662537]   133 662537
 2195214  2012350 17334272      670             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114878] [ 662540]   133 662540
 2192613    17212   294912      496             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114881] [ 662541]   133 662541
 2194212     1338   221184      517             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114884] [ 662542]   133 662542
 2193167      780   188416      508             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114887] [ 662556]   133 662556
 2197872     9552   643072      764             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114890] [ 662559]   133 662559
 2200440    15654   729088     3418             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114901] [ 662560]   133 662560
 2239702   299801  3440640    11516             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114909] [ 665806]   133 665806
 2464749   921966 19582976    88281             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114913] [ 665862]   133 665862
 2419285   976456 19218432    79868             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114917] [ 665968]   133 665968
 2393075   842596 19001344    87827             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114920] [ 666038]   133 666038
 2387447   698377 18935808    89011             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114922] [ 666041]   133 666041
 2417106  1150517 19197952    94609             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114926] [ 666043]   133 666043
 2368198   516669 18759680    71657             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114929] [ 666058]   133 666058
 2367152   752421 18800640    69757             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114932] [ 666131]   133 666131
 2373326   865112 18849792    68493             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114935] [ 666137]   133 666137
 2431131  1206774 19312640    98984             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114940] [ 666188]   133 666188
 2363180   806837 18759680    56174             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114943] [ 666266]   133 666266
 2369595   715551 18784256    64895             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114947] [ 666268]   133 666268
 2398557   802444 19050496    83483             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114950] [ 666313]   133 666313
 2387945   859805 18964480    77019             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114954] [ 666315]   133 666315
 2411280   987194 19148800    66393             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114957] [ 666327]   133 666327
 2389958   779322 18980864    73531             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114962] [ 666403]   133 666403
 2380761   678603 18886656    61683             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114965] [ 666432]   133 666432
 2366968   798506 18796544    57632             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114968] [ 666441]   133 666441
 2515257  1314710 19980288    66781             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114972] [ 666445]   133 666445
 2375433   903633 18866176    59106             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114975] [ 666500]   133 666500
 2405779   997691 19107840    61937             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114979] [ 666508]   133 666508
 2406856   925944 19111936    48066             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114982] [ 666639]   133 666639
 2369685   725350 18817024    51126             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114986] [ 666668]   133 666668
 2398864   830083 19046400    31860             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114989] [ 666670]   133 666670
 2349296   755876 18620416    30572             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114992] [ 666691]   133 666691
 2393287   892246 19005440    45076             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114995] [ 666735]   133 666735
 2401319   935289 19070976    26484             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.114999] [ 666752]   133 666752
 2380063   544926 18857984    24782             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115002] [ 666789]   133 666789
 2418430  1093497 19210240    32148             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115005] [ 666793]   133 666793
 2339296   418434 18513920    28633             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115009] [ 666816]   133 666816
 2376001   639589 18812928    14548             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115011] [ 666823]   133 666823
 2404492  1045778 19099648    10892             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115015] [ 666868]   133 666868
 2367088   875554 18796544     1776             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115018] [ 666871]   133 666871
 2379566   825016 18894848     2265             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115021] [ 666883]   133 666883
 2369865   798628 18821120     1866             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115025] [ 666898]   133 666898
 2422905   943067 19243008     2096             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115028] [ 666900]   133 666900
 2369322   725249 18812928     3776             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115031] [ 666911]   133 666911
 2359212   637610 18722816     2827             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115035] [ 666967]   133 666967
 2397861   896821 19046400     2772             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115038] [ 666968]   133 666968
 2475851  1257159 19673088     3334             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115041] [ 666972]   133 666972
 2477059   968797 19660800     2909             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115044] [ 666973]   133 666973
 2442818  1115803 19402752     3362             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115047] [ 667038]   133 667038
 2365807   658911 18747392     2799             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115051] [ 667046]   133 667046
 2399926  1002120 19062784     2295             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115054] [ 667055]   133 667055
 2371241   821674 18829312     2804             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115058] [ 667059]   133 667059
 2379741   905288 18898944     2016             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115061] [ 667063]   133 667063
 2464180  1204996 19578880     1966             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115065] [ 667078]   133 667078
 2372813   796936 18837504     2490             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115068] [ 667080]   133 667080
 2388087  1048580 18964480     1975             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115071] [ 667095]   133 667095
 2400704   752384 19054592     1737             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115074] [ 667149]     0 667149
 110381    13833   286720      254             0 fwupd
 Oct 16 00:20:05 cpu11 kernel: [1644367.115077] [ 667170]   133 667170
 2368144   501302 18743296     2846             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115079] [ 667280]   133 667280
 2551068  1348511 20279296     2051             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115083] [ 667286]   133 667286
 2413127  1130892 19169280     1977             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115086] [ 667316]   133 667316
 2453458  1057767 19492864     2179             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115090] [ 667334]   133 667334
 2360377   420627 18489344     1739             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115095] [ 667347]   133 667347
 2467566  1213654 19607552     1917             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115099] [ 667360]   133 667360
 2445012   891742 19415040     2480             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115102] [ 667367]   133 667367
 2446838  1065619 19439616     3358             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115105] [ 667384]   133 667384
 2477083  1239232 19681280     1370             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115108] [ 667397]   133 667397
 2327730   489946 18427904     1855             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115111] [ 667537]   133 667537
 2370330   792902 18825216     1271             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115114] [ 667550]   133 667550
 2368018   569864 18792448     1862             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115117] [ 667569]   133 667569
 2456089  1028092 19513344     1488             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115120] [ 667583]   133 667583
 2376472   689012 18874368     2114             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115124] [ 667584]   133 667584
 2403579   894646 19091456     2440             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115126] [ 667620]   133 667620
 2361015   782119 18747392     1675             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115129] [ 667672]   133 667672
 2326497   451655 18362368     1691             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115133] [ 667697]   133 667697
 2459488   893628 19542016     1725             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115137] [ 667719]   133 667719
 2393571   489942 18739200     1631             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115140] [ 667739]   133 667739
 2370564   723532 18821120      719             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115143] [ 667740]   133 667740
 2344873   385926 18362368      925             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115146] [ 667743]   133 667743
 2395908   945641 19030016     1567             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115149] [ 667744]   133 667744
 2382390   765106 18915328      975             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115152] [ 667747]   133 667747
 2421561  1040185 19234816     1296             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115155] [ 667748]   133 667748
 2338907   629757 18534400      680             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115158] [ 667750]   133 667750
 2355418   658372 18698240     1056             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115161] [ 667783]   133 667783
 2411056  1030101 19148800     1267             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115164] [ 667797]   133 667797
 2394930   989270 19017728      973             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115168] [ 667864]   133 667864
 2420866   881757 19226624     1514             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115171] [ 667868]   133 667868
 2416079  1076182 19189760     1134             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115175] [ 667874]   133 667874
 2449475  1084779 19460096     1303             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115177] [ 667875]   133 667875
 2386415   707196 18952192      832             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115181] [ 667884]   133 667884
 2333831   592638 18505728      650             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115184] [ 667897]   133 667897
 2403892   918430 19087360     1032             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115187] [ 667898]   133 667898
 2410483   868234 19148800     1168             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115190] [ 667940]   133 667940
 2377870   963160 18882560     1010             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115194] [ 667945]   133 667945
 2361566   475192 18591744     1015             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115198] [ 667959]   133 667959
 2367100   598089 18784256      672             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115201] [ 667993]   133 667993
 2338406   536640 18513920     1046             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115204] [ 668000]   133 668000
 2356366   955157 18710528      825             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115207] [ 668005]   133 668005
 2478921   958788 19685376     1665             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115209] [ 668060]   133 668060
 2463214  1083155 19566592      717             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115213] [ 668087]   133 668087
 2415386  1080251 19181568      708             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115216] [ 668093]   133 668093
 2404299   890056 19091456      645             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115219] [ 668105]   133 668105
 2463629  1127000 19574784      541             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115221] [ 668108]   133 668108
 2477148  1145401 19681280      875             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115224] [ 668112]   133 668112
 2349226   593779 18653184     1652             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115226] [ 668128]   133 668128
 2430080   977192 19296256      708             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115229] [ 668130]   133 668130
 2383561   895649 18931712      912             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115233] [ 668131]   133 668131
 2331780   454451 18325504      454             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115236] [ 668132]   133 668132
 2364671   817158 18780160      630             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115238] [ 668135]   133 668135
 2328665   726274 18481152      613             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115241] [ 668170]   133 668170
 2387278   945936 18960384      557             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115244] [ 668171]   133 668171
 2359917   792388 18739200      782             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115246] [ 668173]   133 668173
 2352364   555048 18677760      979             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115249] [ 668174]   133 668174
 2408385   957073 19128320      587             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115252] [ 668176]   133 668176
 2313152   407656 18108416      687             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115255] [ 668220]   133 668220
 2359000   748494 18735104      657             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115258] [ 668226]   133 668226
 2311832   434443 18194432      788             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115260] [ 668227]   133 668227
 2351460   588988 18665472      839             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115263] [ 668231]   133 668231
 2355236   624002 18694144     1232             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115267] [ 668236]   133 668236
 2353199   544063 18640896      580             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115271] [ 668248]   133 668248
 2335155   704638 18542592      522             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115274] [ 668283]   133 668283
 2395867   968346 19021824      526             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115277] [ 668316]   133 668316
 2329575   439859 18276352      523             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115279] [ 668373]   133 668373
 2451333   848397 19468288     1951             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115282] [ 668392]   133 668392
 2307054   431530 18128896      696             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115285] [ 668408]   133 668408
 2348848   512934 18612224      442             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115288] [ 668441]   133 668441
 2402077   852670 19079168     1039             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115298] [ 668442]   133 668442
 2355303   602347 18690048      723             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115301] [ 668448]   133 668448
 2286300   389037 18014208      568             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115304] [ 668451]   133 668451
 2391450   804620 18989056      688             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115306] [ 668456]   133 668456
 2311822   558123 18354176      845             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115309] [ 668457]   133 668457
 2375696   734785 18857984      505             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115312] [ 668458]   133 668458
 2421432   858280 19234816      713             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115315] [ 668496]   133 668496
 2391657   774375 18993152      582             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115319] [ 668499]   133 668499
 2362119   761190 18759680      804             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115322] [ 668502]   133 668502
 2355130   627657 18694144      561             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115324] [ 668505]   133 668505
 2343225   521105 18579456      571             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115327] [ 668506]   133 668506
 2363628   557165 18743296      564             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115330] [ 668507]   133 668507
 2382254   717356 18915328      441             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115333] [ 668508]   133 668508
 2321866   398990 18108416      667             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115339] [ 668526]   133 668526
 2403978   981960 19083264      796             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115341] [ 668528]   133 668528
 2379369   855111 18894848      641             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115344] [ 668531]   133 668531
 2418254   829681 19206144      595             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115347] [ 668532]   133 668532
 2330037   424382 18362368      643             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115349] [ 668535]   133 668535
 2320234   389854 18034688      497             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115352] [ 668599]   133 668599
 2457871   901370 19513344      763             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115355] [ 668611]   133 668611
 2398837   935621 19050496      562             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115358] [ 668633]   133 668633
 2294999   475484 18210816      471             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115361] [ 668634]   133 668634
 2394145   885622 19013632      671             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115364] [ 668640]   133 668640
 2342641   479414 18522112      658             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115367] [ 668641]   133 668641
 2351273   528891 18649088      805             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115369] [ 668774]   133 668774
 2494484   954076 19816448     2656             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115372] [ 668814]   133 668814
 2443278   803108 19402752      598             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115374] [ 668815]   133 668815
 2796063  1140647 22216704      658             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115378] [ 668823]   133 668823
 2336605   325163 17317888      526             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115380] [ 668911]   133 668911
 2425876   945413 19255296      479             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115383] [ 668933]   133 668933
 2335924   396079 18313216     1122             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115385] [ 668935]   133 668935
 2362945   357814 17186816      571             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115388] [ 669018]   133 669018
 2360750   413156 18292736      797             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115392] [ 669043]   133 669043
 2350409   381002 18055168      524             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115395] [ 669044]   133 669044
 2296811   236265 16510976      960             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115398] [ 669048]   133 669048
 2300770   206764 14393344      534             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115401] [ 669077]   133 669077
 2327264   406585 18100224      557             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115403] [ 669094]   133 669094
 2506606   762210 19910656      825             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115406] [ 669138]   133 669138
 2302055   187977 12500992      576             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115409] [ 669210]   133 669210
 2331634   629975 18518016      517             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115411] [ 669220]   133 669220
 2375192   846694 18862080      625             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115414] [ 669252]   133 669252
 2304722   404707 18145280      770             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115417] [ 669306]   133 669306
 2483176   992873 19709952      482             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115420] [ 669331]   133 669331
 2482967   940090 19726336      619             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115424] [ 669418]   133 669418
 2381810   796735 18915328      717             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115428] [ 669459]   133 669459
 2354454   497049 18616320     3921             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115432] [ 669462]   133 669462
 2326153   385541 18182144      607             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115435] [ 669470]   133 669470
 2304311   324584 17547264      715             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115438] [ 669476]   133 669476
 2394955   789008 19021824      608             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115441] [ 669478]   133 669478
 2380706   946924 18907136      711             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115444] [ 669483]   133 669483
 2347195   534151 18571264      519             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115446] [ 669484]   133 669484
 2348300   346606 17346560     1961             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115449] [ 669485]   133 669485
 2334832   326072 17059840     1094             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115452] [ 669498]   133 669498
 2400951   728343 19070976     4549             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115456] [ 669499]   133 669499
 2350499   618190 18657280     1868             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115459] [ 669511]   133 669511
 2346917   395089 18251776     3906             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115461] [ 669514]   133 669514
 2303504   377795 18022400      920             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115464] [ 669515]   133 669515
 2287327   290918 17166336     1788             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115467] [ 669573]   133 669573
 2366551   376293 17920000     2567             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115470] [ 669574]   133 669574
 2293563   162219 10108928      762             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115473] [ 669575]   133 669575
 2356168   396320 18259968     6533             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115476] [ 669581]   133 669581
 2313884   259552 15249408     4212             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115480] [ 669603]   133 669603
 2400208   618369 19062784     2343             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115483] [ 669604]   133 669604
 2471911   928412 19615744     3904             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115486] [ 669611]   133 669611
 2321938   313233 16855040      814             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115489] [ 669613]   133 669613
 2300645   282589 16547840     1006             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115492] [ 669615]   133 669615
 2268683   128282  8761344     2803             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115495] [ 669627]   133 669627
 2485833   784031 19746816     1003             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115498] [ 669628]   133 669628
 2335783   579066 18530304     1101             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115501] [ 669629]   133 669629
 2314182   417982 18366464     3351             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115504] [ 669636]   133 669636
 2385193   527259 18849792     1592             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115508] [ 669637]   133 669637
 2261309   223998 15880192      885             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115511] [ 669694]   133 669694
 2436912   869136 19353600     4554             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115515] [ 669718]   133 669718
 2298663   376421 18034688      827             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115518] [ 669722]   133 669722
 2431256   805070 19304448     1672             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115522] [ 669728]   133 669728
 2486767   906554 19759104     1606             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115525] [ 669729]   133 669729
 2460698   826427 19550208     1001             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115528] [ 669739]   133 669739
 2335787   402344 18288640     2233             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115531] [ 669748]   133 669748
 2244227    78375  3833856     1462             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115534] [ 669750]   133 669750
 2320027   264183 14766080      853             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115537] [ 669752]   133 669752
 2241738    73108  3022848      422             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115540] [ 669759]   133 669759
 2451182  1015872 19468288      581             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115543] [ 669767]   133 669767
 2274792   224547 15638528      488             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115554] [ 672091]     0 672091
 19064     1376   126976        0             0 cupsd
 Oct 16 00:20:05 cpu11 kernel: [1644367.115557] [ 672096]     0 672096
 43015     1073   106496        0             0 cups-browsed
 Oct 16 00:20:05 cpu11 kernel: [1644367.115568] [ 673101]   112 673101
 10402      641    69632        0             0 pickup
 Oct 16 00:20:05 cpu11 kernel: [1644367.115576] [ 673160]   133 673160
 2458726   741431 16121856      426             0 postgres
 Oct 16 00:20:05 cpu11 kernel: [1644367.115586] [ 673209]     0 673209
 42146     1254    86016      252             0 (lcluster)
 /system-
 result 'oom-kill'.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5798>
