[PostGIS] #5799: ST_TileEnvelope with margin is not clipped fully to WM extent
trac at osgeo.org
Thu Oct 17 11:43:48 PDT 2024
Reporter: mdavis | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: postgis | Version: 3.5.x
Keywords: |
When executing [https://postgis.net/docs/manual-3.5/ST_TileEnvelope.html
ST_TileEnvelope] with a `margin` parameter the resulting polygon is only
partially clipped to the WebMercator maximum extents. This causes
problems in downstream processing (e.g. when converting to geodetic via
`ST_Transform( env, 4326)`).
For example, the tile envelope for (z=1, x=0, y=1) is:
SELECT ST_AsText( ST_TileEnvelope(1,0,1));
POLYGON((-20037508.342789244 -20037508.342789244,-20037508.342789244 0,0
0,0 -20037508.342789244,-20037508.342789244 -20037508.342789244))
With a margin of 0.1 the result is:
SELECT ST_AsText( ST_TileEnvelope(1,0,1, margin => 0.1));
POLYGON((-22041259.17706817 -20037508.342789244,-22041259.17706817
2003750.834278924,2003750.8342789263 2003750.834278924,2003750.8342789263
-20037508.342789244,-22041259.17706817 -20037508.342789244))
This is clipped in the Y dimension to the WM extents (```-20037508.342789
-20037508.342789, 20037508.342789 20037508.342789```). But it extends
beyond the X extent to the left. It should also be clipped in the X
dimension, to avoid causing problems with further computation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5799>
