[PostGIS] #5803: Setup new bessie on osgeo8
trac at osgeo.org
Tue Oct 29 20:36:26 PDT 2024
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Website Management, Bots
Component: QA/buildbots | Version: master
Keywords: |
I've started setting up a new bessie on osgeo8. I had some obstacles
getting the networking to work, so had to add static ip and route.
I'll figure that out later.
But anyway I think I'm about 80% done with her.
This new bessie is freebsd 14.1 -- used this VM image to setup
https://download.freebsd.org/ftp/releases/VM-
IMAGES/14.1-RELEASE/amd64/Latest/FreeBSD-14.1-RELEASE-amd64-zfs.qcow2.xz
Old bessie is no longer functional, cause she's too old to be able to
cleanly install openjdk17 (what is installed on debbie and the berries)
When I'm done with her you should be able to access her via
ssh jenkins at osgeo8-bessie
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5803>
