[PostGIS] #5803: Setup new bessie on osgeo8
trac at osgeo.org
Thu Oct 31 06:17:28 PDT 2024
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Website Management, Bots
Component: QA/buildbots | Version: master
Resolution: | Keywords:
Comment (by robe):
I have all dependencies installed on new bessie but sadly she's failing on
regrssion testing
15:21:25 Creating database 'postgis_reg-3.6'.
15:21:25 Loading PostGIS in 'postgis_reg-3.6 using scripts from
/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/e8d47bb440139d9f6c90acfd234e2fe6a668ba3d/regress/00
-regress-install/share/contrib/postgis'
15:21:25 failed (Error encountered loading
-regress-install/share/contrib/postgis/postgis.sql:
/home/jenkins/tmp/pgis_reg_e8d47bb440139d9f6c90acfd234e2fe6a668ba3d/regress_log.tmp)
15:21:25
15:21:25 NOTICE: schema "public" already exists, skipping
15:21:25
psql:/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/e8d47bb440139d9f6c90acfd234e2fe6a668ba3d/regress/00
-regress-install/share/contrib/postgis/postgis.sql:72: ERROR: could not
access file "$libdir/plpgsql": No such file or directory
15:21:25
15:21:25 gmake[1]: *** [regress/runtest.mk:24: check-regress] Error 1
15:21:25 gmake[1]: Leaving directory
'/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/e8d47bb440139d9f6c90acfd234e2fe6a668ba3d'
15:21:25 *** Error code 2
15:21:25
15:21:25 Stop.
15:21:25 make: stopped in
15:21:26 Build step 'Execute shell' marked build as failure
15:21:26 [Gitea] do not publish assets due to build being non-Successfully
15:21:26 Finished: FAILURE
perhaps plpgsql needs to be installed separately like I need a postgresql-
contrib
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5803#comment:1>
