[SCM] PostGIS branch master updated. 3.5.0-41-ge8d47bb44
Wed Oct 30 12:14:16 PDT 2024
the project "PostGIS".
       via  e8d47bb440139d9f6c90acfd234e2fe6a668ba3d (commit)
      from  b32c5c120d7ba40801b27b947337d9da509ca799 (commit)
revisions in full, below.
commit e8d47bb440139d9f6c90acfd234e2fe6a668ba3d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Oct 30 12:13:55 2024 -0700
    Round even grid/scale factors more precisely.
    Closes #5424
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index f8c11405c..9f7cc3b01 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1398,11 +1398,15 @@ typedef struct gridspec_t
 	double ysize;
 	double zsize;
 	double msize;
+    double xscale;
+    double yscale;
+    double zscale;
+    double mscale;
 gridspec;
-extern LWGEOM* lwgeom_grid(const LWGEOM *lwgeom, const gridspec *grid);
-extern void lwgeom_grid_in_place(LWGEOM *lwgeom, const gridspec *grid);
+extern LWGEOM* lwgeom_grid(const LWGEOM *lwgeom, gridspec *grid);
+extern void lwgeom_grid_in_place(LWGEOM *lwgeom, gridspec *grid);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index f1e28eac0..e51062b00 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -432,7 +432,7 @@ int lwtin_is_closed(const LWTIN *tin);
 * Snap to grid
-void ptarray_grid_in_place(POINTARRAY *pa, const gridspec *grid);
+void ptarray_grid_in_place(POINTARRAY *pa, gridspec *grid);
 * What side of the line formed by p1 and p2 does q fall?
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 86bd54143..c22fb621e 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -2226,11 +2226,51 @@ lwgeom_startpoint(const LWGEOM *lwgeom, POINT4D *pt)
+static inline double
+snap_to_int(double val)
+	const double tolerance = 1e-6;
+    double rintval = rint(val);
+    if (fabs(val - rintval) < tolerance)
+        return rintval;
+    return val;
+ * See https://github.com/libgeos/geos/pull/956
+ * We use scale for rounding when gridsize is < 1 and
+ * gridsize for rounding when scale < 1.
+static inline void
+condition_gridspec_scale(gridspec *grid)
+	if(grid->xsize > 0)
+		if(grid->xsize < 1)
+			grid->xscale = snap_to_int(1/grid->xsize);
+		else
+			grid->xsize = snap_to_int(grid->xsize);
+	if(grid->ysize > 0)
+		if(grid->ysize < 1)
+			grid->yscale = snap_to_int(1/grid->ysize);
+		else
+			grid->ysize = snap_to_int(grid->ysize);
 void
-lwgeom_grid_in_place(LWGEOM *geom, const gridspec *grid)
+lwgeom_grid_in_place(LWGEOM *geom, gridspec *grid)
 	if (!geom) return;
 	if (lwgeom_is_empty(geom)) return;
+	condition_gridspec_scale(grid);
 	switch ( geom->type )
 		case POINTTYPE:
@@ -2328,7 +2368,7 @@ lwgeom_grid_in_place(LWGEOM *geom, const gridspec *grid)
 LWGEOM *
-lwgeom_grid(const LWGEOM *lwgeom, const gridspec *grid)
+lwgeom_grid(const LWGEOM *lwgeom, gridspec *grid)
 	LWGEOM *lwgeom_out = lwgeom_clone_deep(lwgeom);
 	lwgeom_grid_in_place(lwgeom_out, grid);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index cabf679a9..307888488 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -2088,7 +2088,7 @@ ptarray_startpoint(const POINTARRAY *pa, POINT4D *pt)
 void
-ptarray_grid_in_place(POINTARRAY *pa, const gridspec *grid)
+ptarray_grid_in_place(POINTARRAY *pa, gridspec *grid)
 	uint32_t j = 0;
 	POINT4D *p, *p_out = NULL;
@@ -2108,11 +2108,24 @@ ptarray_grid_in_place(POINTARRAY *pa, const gridspec *grid)
 		if (ndims > 3)
 			m = p->m;
-		if (grid->xsize > 0)
-			x = rint((x - grid->ipx) / grid->xsize) * grid->xsize + grid->ipx;
+		if (grid->xsize > 0) {
+			if (grid->xsize < 1)
+				x = rint((x - grid->ipx) * grid->xscale) / grid->xscale + grid->ipx;
+			else
+				x = rint((x - grid->ipx) / grid->xsize) * grid->xsize + grid->ipx;
-		if (grid->ysize > 0)
-			y = rint((y - grid->ipy) / grid->ysize) * grid->ysize + grid->ipy;
+		if (grid->ysize > 0) {
+			if (grid->ysize < 1)
+				y = rint((y - grid->ipy) * grid->yscale) / grid->yscale + grid->ipy;
+			else
+				y = rint((y - grid->ipy) / grid->ysize) * grid->ysize + grid->ipy;
 		/* Read and round this point */
 		/* Z is always in third position */
diff --git a/postgis/mvt.c b/postgis/mvt.c
index 14691b551..da9318c69 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -144,7 +144,7 @@ static inline uint32_t c_int(enum mvt_cmd_id id, uint32_t count)
 static inline uint32_t p_int(int32_t value)
-	return (value << 1) ^ ((int64_t)value >> 31);
+	return (value << 1) ^ (value >> 31);
 static uint32_t encode_ptarray(enum mvt_type type, POINTARRAY *pa, uint32_t *buffer, int32_t *px, int32_t *py)
@@ -877,7 +877,7 @@ mvt_clip_and_validate_geos(LWGEOM *lwgeom, uint8_t basic_type, uint32_t extent,
 	if (clip_geom)
-		gridspec grid = {0, 0, 0, 0, 1, 1, 0, 0};
+		gridspec grid = {0, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0};
 		GBOX bgbox;
 		bgbox.xmax = bgbox.ymax = (double)extent + (double)buffer;
 		bgbox.xmin = bgbox.ymin = -(double)buffer;
@@ -933,7 +933,7 @@ LWGEOM *mvt_geom(LWGEOM *lwgeom, const GBOX *gbox, uint32_t extent, uint32_t buf
 	bool clip_geom)
 	AFFINE affine = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
 	double width = gbox->xmax - gbox->xmin;
 	double height = gbox->ymax - gbox->ymin;
 	double fx, fy;
diff --git a/regress/core/regress_proj_pipeline.sql b/regress/core/regress_proj_pipeline.sql
index 2b5b98998..a72c3eed3 100644
--- a/regress/core/regress_proj_pipeline.sql
+++ b/regress/core/regress_proj_pipeline.sql
@@ -15,9 +15,9 @@ SELECT '5', ST_SRID(ST_TransformPipeline('SRID=4326;POINT(174 -37)'::geometry, '
 SELECT '6', ST_SRID(ST_TransformPipeline('SRID=4326;POINT(174 -37)'::geometry, '+proj=pipeline +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +proj=tmerc +lat_0=0 +lon_0=173 +k=0.9996 +x_0=1600000 +y_0=10000000 +ellps=GRS80', 12345));
 -- GDA2020 is complicated, check it works
-SELECT '7', ST_AsText(ST_SnapToGrid(ST_TransformPipeline('SRID=4283;POINT(151.2 -33.8)'::geometry, 'urn:ogc:def:coordinateOperation:EPSG::8048'), 0.1));
+SELECT '7', ST_AsText(ST_TransformPipeline('SRID=4283;POINT(151.2 -33.8)'::geometry, 'urn:ogc:def:coordinateOperation:EPSG::8048'),1);
 -- testing inverse pipelines; also checks rad->deg on results
-SELECT '8', ST_AsText(ST_SnapToGrid(ST_InverseTransformPipeline('SRID=32631;POINT(426857 5427937)'::geometry, 'urn:ogc:def:coordinateOperation:EPSG::16031'), 0.1));
+SELECT '8', ST_AsText(ST_InverseTransformPipeline('SRID=32631;POINT(426857 5427937)'::geometry, 'urn:ogc:def:coordinateOperation:EPSG::16031'), 1);
 SELECT '9', ST_SRID(ST_InverseTransformPipeline('SRID=32631;POINT(426857 5427937)'::geometry, 'urn:ogc:def:coordinateOperation:EPSG::16031', 12345));
diff --git a/regress/core/regress_proj_pipeline_expected b/regress/core/regress_proj_pipeline_expected
index 43834cbd0..8d7891a72 100644
--- a/regress/core/regress_proj_pipeline_expected
+++ b/regress/core/regress_proj_pipeline_expected
@@ -4,6 +4,6 @@ ERROR:  could not parse coordinate operation 'bad coordinate transform pipeline'
 ERROR:  lwgeom_transform_pipeline: Failed to transform
 5|0
 6|12345
-7|POINT(151.20000000000002 -33.800000000000004)
+7|POINT(151.2 -33.8)
 8|POINT(2 49)
 9|12345
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 40df77830..8228e59ca 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1510,6 +1510,10 @@ SELECT '#5320', ST_SimplifyPreserveTopology('0106000020E864000001000000010300000
 DROP PROCEDURE IF EXISTS p_force_parellel_mode(text);
 SELECT '#5378', ST_SRID( ST_Buffer(ST_GeomFromText('POINT(-94 29.53)', 4269)::geography, 12)::geometry );
+SELECT '#5425', ST_AsText(ST_SnapToGrid(
+  ST_SnapToGrid('POINT(1.23456789 9.87654321)'::geometry, 0.001),
+  0.000001) );
 SELECT '#5627' AS ticket, bool_and(ST_Intersects(
     'MULTIPOINT(EMPTY,(-378 574))'::geometry,
     geom))
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index f2ebc6e25..e81b530ef 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -468,6 +468,7 @@ ERROR:  Line has no points
 ERROR:  Geometry contains invalid coordinates
 #5378|4269
+#5425|POINT(1.235 9.877)
 #5627|t
 #5604|2|POINT(0 0)|2|POINT(-2 0)
 #5639|fullywithin1|t
Summary of changes:
 liblwgeom/liblwgeom.h.in                    |  8 ++++--
 liblwgeom/liblwgeom_internal.h              |  2 +-
 liblwgeom/lwgeom.c                          | 44 +++++++++++++++++++++++++++--
 liblwgeom/ptarray.c                         | 23 +++++++++++----
 postgis/mvt.c                               |  6 ++--
 regress/core/regress_proj_pipeline.sql      |  4 +--
 regress/core/regress_proj_pipeline_expected |  2 +-
 regress/core/tickets.sql                    |  4 +++
 regress/core/tickets_expected               |  1 +
 9 files changed, 78 insertions(+), 16 deletions(-)
hooks/post-receive
