[PostGIS] #5807: Uncorrelated ST_Transform runs on each filter evaluation
    trac at osgeo.org
    Thu Oct 31 19:27:05 PDT 2024
  Reporter:  lnicola  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.5.x
Resolution:           |   Keywords:
Comment (by robe):
 I concur I get same results on:
 POSTGIS="3.5.0 3.5.0" [EXTENSION] PGSQL="170" GEOS="3.13.0-CAPI-1.19.0"
 SFCGAL="SFCGAL 1.5.2, CGAL 5.6.1, BOOST 1.84.0" PROJ="8.2.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=C:\Users\Administrator\AppData\Local/proj
 DATABASE_PATH=C:\Program
 Files\PostgreSQL\16\share\contrib\postgis-3.5\proj\proj.db" (compiled
 against PROJ 8.13.0) GDAL="GDAL 3.9.2, released 2024/08/13"
 LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
 (Internal)" TOPOLOGY RASTERPostgreSQL 17.0 on x86_64-windows, compiled by
 msvc-19.41.34120, 64-bit
 I tried increasing cost of ST_Transform to 50000 and did not change the
 plan.
 It's nice to see though that the offset 0 hack of olden times still works.
 e.g. the offset 0 ones do the right thing only executing ST_Transform: 12
 times, ST_Intersects: 1587629
 though the plans look pretty much the same to me so hard to tell you are
 loosing 4 seconds with the redundant ST_Transform
 with tiles as (
     select tile_id, ST_Transform(geom, 2157) as geom
     from shape_tiles_s2
     where tile_id in ('29UMA', '29UMT', '29UMU', '29UMV', '29UNA',
 '29UNT', '29UNU', '29UNV', '29UPA', '29UPT', '29UPU', '29UPV')
 offset 0
 select count(*)
 from polygons, tiles
 where ST_Intersects(polygons.wkb_geometry, tiles.geom);
 explain (analyze, buffers, summary, settings) with tiles as (
 select tile_id, ST_Transform(geom, 2157) as geom    from shape_tiles_s2
 where tile_id in ('29UMA', '29UMT', '29UMU', '29UMV', '29UNA', '29UNT',
 '29UPU', '29UPV') offset 0) select count(*)  from polygons, tiles  where
 QUERY PLAN
  Aggregate  (cost=28771.51..28771.52 rows=1 width=8) (actual
 time=15574.398..15574.399 rows=1 loops=1)
    Buffers: shared hit=571995 read=748300
    ->  Nested Loop  (cost=0.58..28730.47 rows=16418 width=0) (actual
 time=151.646..15301.244 rows=1546576 loops=1)
          ->  Index Scan using shape_tiles_s2_pkey on shape_tiles_s2
 (cost=0.29..1555.69 rows=12 width=56) (actual time=149.562..149.855
 rows=12 loops=1)
                Index Cond: (tile_id = ANY
 ('{29UMA,29UMT,29UMU,29UMV,29UNA,29UNT,29UNU,29UNV,29UPA,29UPT,29UPU,29UPV}'::bpchar[]))
                Buffers: shared hit=70 read=26
          ->  Index Scan using ix_polygons_geom on polygons
 (cost=0.29..2263.18 rows=137 width=498) (actual time=0.712..1239.095
 rows=128881 loops=12)
                Index Cond: (wkb_geometry &&
 (st_transform(shape_tiles_s2.geom, 2157)))
                Filter: st_intersects(wkb_geometry,
                Rows Removed by Filter: 3421
                Buffers: shared hit=571925 read=748274
  Planning:
    Buffers: shared hit=212 read=87
  Planning Time: 7.071 ms
  Execution Time: 15575.050 ms
 (17 rows)
 Similar success with:
 explain (analyze, buffers, summary)  select count(*)
 from polygons, (    select tile_id, ST_Transform(geom, 2157) as geom
     from shape_tiles_s2
 offset 0) AS tiles
        QUERY
 PLAN
 time=15084.127..15084.129 rows=1 loops=1)
    Buffers: shared hit=571964 read=748192
 time=0.954..14765.809 rows=1546576 loops=1)
 (cost=0.29..1555.69 rows=12 width=56) (actual time=0.158..0.433 rows=12
 loops=1)
                Buffers: shared read=4
 (cost=0.29..2263.18 rows=137 width=498) (actual time=0.600..1206.879
                Buffers: shared hit=571964 read=748188
  Planning Time: 0.478 ms
  Execution Time: 15084.266 ms
 (14 rows)
  select funcname, calls, total_time  from pg_stat_user_functions WHERE
 funcname IN('st_intersects', 'st_transform');
   funcname    |  calls  | total_time
  st_intersects | 1587629 |   4775.398
  st_transform  |      12 |      0.254
 (2 rows)
 vs.  bad result
 SELECT pg_stat_reset();
     from shape_tiles_s2
 ) AS tiles
 QUERY PLAN
  Aggregate  (cost=234271.40..234271.41 rows=1 width=8) (actual
 time=27241.602..27241.603 rows=1 loops=1)
    Buffers: shared hit=571259 read=748897
    ->  Nested Loop  (cost=125.58..234230.35 rows=16418 width=0) (actual
 time=0.957..26859.793 rows=1546576 loops=1)
 (cost=0.29..55.69 rows=12 width=120) (actual time=0.138..0.166 rows=12
 loops=1)
 (cost=125.29..19513.18 rows=137 width=498) (actual time=0.656..2213.554
                Filter: st_intersects(st_transform(shape_tiles_s2.geom,
 2157), wkb_geometry)
                Buffers: shared hit=571259 read=748893
  Planning Time: 0.266 ms
  Execution Time: 27241.830 ms
  st_intersects | 1587629 |   4800.759
  st_transform  | 1587641 |  10899.837
 (2 rows)
 explain (analyze, buffers, summary) with tiles as materialized (
 57) as geom     from shape_tiles_s2     where tile_id in ('29UMA',
 '29UMT', '29UMU', '29UMV', '29UNA', '29UNT', '29UNU', '29UNV', '29UPA',
 '29UPT', '29UPU', '
 29UPV'))select count(*) from polygons, tiles where
 QUERY PLAN
  Aggregate  (cost=28771.63..28771.64 rows=1 width=8) (actual
 time=15057.196..15057.198 rows=1 loops=1)
    Buffers: shared hit=571903 read=748253
    CTE tiles
 (cost=0.29..1555.69 rows=12 width=38) (actual time=0.159..0.421 rows=12
 loops=1)
    ->  Nested Loop  (cost=0.29..27174.90 rows=16418 width=0) (actual
 time=0.975..14775.543 rows=1546576 loops=1)
          ->  CTE Scan on tiles  (cost=0.00..0.24 rows=12 width=32) (actual
 time=0.165..0.475 rows=12 loops=1)
 (cost=0.29..2263.18 rows=137 width=498) (actual time=0.555..1208.768
                Index Cond: (wkb_geometry && tiles.geom)
                Filter: st_intersects(wkb_geometry, tiles.geom)
                Buffers: shared hit=571903 read=748249
  Planning Time: 0.463 ms
  Execution Time: 15057.368 ms
 (17 rows)
 (2 rows)
 What annoys me is the plans all look pretty much the same and yet the
 materialized and offset 0 ones are clearly winners because they shave off
 4 seconds not running ST_Transform all those extra times.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5807#comment:4>
