[PostGIS] #5807: Uncorrelated ST_Transform runs on each filter evaluation
trac at osgeo.org
Thu Oct 31 09:39:10 PDT 2024
Reporter: lnicola | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Description changed by lnicola:
Old description:
> During the following query, {{{ST_Transform}}} runs 1817760 times:
> with tiles as (
> select tile_id, ST_Transform(geom, 2157) as geom
> from shape_tiles_s2
> where tile_id in ('29UMA', '29UMT', '29UMU', '29UMV', '29UNA',
> '29UNT', '29UNU', '29UNV', '29UPA', '29UPT', '29UPU', '29UPV')
> select count(*)
> from polygons, tiles
> where ST_Intersects(polygons.wkb_geometry, tiles.geom);
> If you switch to a materialized CTE, it only runs 12 times:
> with tiles as materialized (
> from shape_tiles_s2
> select count(*)
> Don't read too much into the CTE. I checked with robe, and pretty much
> every other way to write it (with a join, with a subquery, with a lateral
> join) is even slower than the two CTE version.
> To test, use:
> set track_functions = 'all';
> select * from pg_stat_user_functions; select pg_stat_reset();
> You can download the {{{polygons}}} dataset from
> https://data.europa.eu/data/datasets/d18f6f95-1d96-4b86-a4ba-
> 291a416e45bb?locale=en, it's the one called "Anonymous LPIS 2023
> Parcels", import using e.g.:
> ogr2ogr -nln polygons -nlt geometry "PG:host=127.0.0.1 user=postgres
> dbname=postgres" GEOSERVICESHELP-213-PARCELS-ANON.shp
> The {{{shape_tiles_s2}}} table is attached. It's probably derived from
> {{{S2A_OPER_GIP_TILPAR_MPC__20151209T095117_V20150622T000000_21000101T000000_B00.zip}}},
> which you can find on https://sentiwiki.copernicus.eu/web/s2-products.
New description:
with tiles as (
from shape_tiles_s2
select count(*)
from shape_tiles_s2
select count(*)
To test, use:
291a416e45bb?locale=en, it's the one called "Anonymous LPIS 2023 Parcels",
import using e.g.:
Tested on
POSTGIS="3.5.0 d2c3ca4" [EXTENSION] PGSQL="170" GEOS="3.13.0-CAPI-1.19.0"
PROJ="9.5.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ
9.13.0) LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" TOPOLOGY
and
POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="160" GEOS="3.12.2-CAPI-1.18.2"
PROJ="9.4.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/pgsql/.local/share/proj
DATABASE_PATH=/usr/proj94/share/proj/proj.db" LIBXML="2.9.13"
LIBJSON="0.14" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5807#comment:3>
