[PostGIS] #5780: Random errors on GHA postgis install some sort of incomplete scripts
trac at osgeo.org
Thu Sep 19 06:17:24 PDT 2024
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.0
Component: install | Version: master
Resolution: | Keywords:
Comment (by robe):
Just a note about the commonality of these, they all involve random syntax
errors in raster scripts primarily the rtpostgis_upgrade.sql script
and here is another pattern of failure not with sql script errors
#strip BEGIN/COMMIT since these are not allowed in extensions
make[3]: Leaving directory '/src/postgis/raster/rt_pg'
make[3]: *** [Makefile:156: rtpostgis_upgrade.sql.in] Error 255
make[3]: *** Deleting file 'rtpostgis_upgrade.sql.in'
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile:76:
../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql] Error 2
make[2]: *** Deleting file
'../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql'
make[2]: *** Waiting for unfinished jobs....
# WARNING: we should make sure these are not internal to function bodies
cat ../../postgis/common_before_upgrade.sql
../../postgis/postgis_before_upgrade.sql
sql/postgis_upgrade_for_extension.sql.in
../../postgis/postgis_after_upgrade.sql
../../postgis/common_after_upgrade.sql | /usr/bin/perl -pe 's/BEGIN\;//g ;
s/COMMIT\;//g' > sql/postgis_upgrade_for_extension.sql
make[2]: *** [Makefile:76: ../../raster/rt_pg/uninstall_rtpostgis.sql]
Error 2
make[2]: *** Deleting file '../../raster/rt_pg/uninstall_rtpostgis.sql'
make[2]: *** [Makefile:76: ../../raster/rt_pg/rtpostgis_drop.sql] Error 2
make[2]: Leaving directory '/src/postgis/extensions/postgis'
make[2]: *** Deleting file '../../raster/rt_pg/rtpostgis_drop.sql'
make[1]: *** [Makefile:36: all] Error 1
make[1]: Leaving directory '/src/postgis/extensions'
make: *** [GNUmakefile:34: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5780#comment:1>
