[PostGIS] #5780: Random errors on GHA postgis install some sort of incomplete scripts
PostGIS trac at osgeo.org
Thu Sep 19 05:58:55 PDT 2024
 Reporter:  robe     |      Owner:  strk
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.5.0
Component:  install  |    Version:  master
 Keywords:           |
 I just noticed GHA has been failing for a couple of runs, but it's random.
 So guessing it has to do with parallel jobs?
 https://github.com/postgis/postgis/actions/runs/10935290396/job/30356784011
 Errors like
 _postgis_drop_function_by_signature
 (1 row)
 psql:/src/postgis/regress/00-regress-
 install/share/contrib/postgis/rtpostgis_upgrade.sql:843: ERROR:  syntax
 error at or near "DECLARE"
 LINE 122: DECLARE
 and
 (1 row)
 install/share/contrib/postgis/rtpostgis_upgrade.sql:4433: ERROR:  syntax
 error at or near "CREATE"
 LINE 39: CREATE OR REPLACE FUNCTION _postgis_drop_function_by_identit...
 CONTEXT:  invalid type name "CREATE OR REPLACE FUNCTION
 _postgis_drop_function_by_identity(
         function_name text,
         function_arguments text,
         deprecated_in_version text "
 I know strk had completed some changes recently for parallelism, which is
 around the time these failures started happening.
 The bots failing is random.  It's not all but across various PG versions,
 GEOS versions, and GDAL versions
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5780>
