[SCM] PostGIS branch master updated. 3.5.0beta1-7-g2be69a364
Wed Sep 18 14:53:09 PDT 2024
the project "PostGIS".
       via  2be69a364b520850c1ae58cb587d7f04ba59f753 (commit)
      from  fd3b52f0d7b59e59e3ffa92cac00b22a8e274fd4 (commit)
revisions in full, below.
commit 2be69a364b520850c1ae58cb587d7f04ba59f753
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Sep 18 17:51:59 2024 -0400
    Fix link labels.
    Should use refname instead of refid
    Closes #5778 for PostGIS 3.5.0
diff --git a/doc/xsl/list_3d_functions.xml.xsl b/doc/xsl/list_3d_functions.xml.xsl
index 46c2460d6..5579df67f 100644
--- a/doc/xsl/list_3d_functions.xml.xsl
+++ b/doc/xsl/list_3d_functions.xml.xsl
@@ -27,15 +27,19 @@
 					<xsl:variable name='comment'>
 						<xsl:value-of select="normalize-space(translate(translate(db:refnamediv/db:refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
 					</xsl:variable>
 					<xsl:variable name="refid">
 						<xsl:value-of select="@xml:id" />
 					</xsl:variable>
+					<xsl:variable name="refname">
+						<xsl:value-of select="db:refnamediv/db:refname" />
+					</xsl:variable>
 			<!-- For each section if there is note that it supports 3d catalog it -->
 						<xsl:for-each select="db:refsection">
 							<xsl:choose>
 								<xsl:when test="descendant::node()[@conformance='3d']">
-									<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refid" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
+									<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
 								</xsl:when>
 							</xsl:choose>
 						</xsl:for-each>
diff --git a/doc/xsl/list_sqlmm_functions.xml.xsl b/doc/xsl/list_sqlmm_functions.xml.xsl
index 620b74e62..1d157d101 100644
--- a/doc/xsl/list_sqlmm_functions.xml.xsl
+++ b/doc/xsl/list_sqlmm_functions.xml.xsl
@@ -26,15 +26,19 @@
 					</xsl:variable>
 					</xsl:variable>
+					</xsl:variable>
 			<!-- For each section if there is note that it implements SQL/MM catalog it -->
 								<xsl:choose>
 									<xsl:when test="descendant::node()[@conformance='sqlmm']">
 									</xsl:when>
 								</xsl:choose>
 						</xsl:for-each>
Summary of changes:
 doc/xsl/list_3d_functions.xml.xsl    | 6 +++++-
 doc/xsl/list_sqlmm_functions.xml.xsl | 6 +++++-
 2 files changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
