[PostGIS] #5779: create_upgrade.pl fails for 3.5.0-beta1
trac at osgeo.org
Fri Sep 20 07:33:50 PDT 2024
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: build | Version: master
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:7 Bas Couwenberg]:
> You can probably make it fail with more parallel processes, on my system
I use 11 of the 12 cores.
Can you retry with @strk patch he committed at Temptative fix in
[be1c2273cdfe0490a43b0148bb8f18ce57a63916/git]
Ticket URL: <https://trac.osgeo.org/$(basename)s/ticket/5779#comment:9>
