[PostGIS] #5781: Concave Hull returning multi poly with polygons
trac at osgeo.org
Mon Sep 23 13:20:34 PDT 2024
Reporter: latot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
I thought this was an issue with the old geos, but looking at a server I
have running:
POSTGIS="3.4.1 3.4.1" [EXTENSION] PGSQL="150" GEOS="3.12.1-CAPI-1.18.1"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.78.0" PROJ="8.2.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=C:\Users\paragon\AppData\Local/proj
DATABASE_PATH=C:\Program
Files\PostgreSQL\15\share\contrib\postgis-3.4\proj\proj.db"
LIBXML="2.9.14" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
(Internal)"
However passing 0 for shrink percent I'm tempted to say should be illegal,
so it's probably treating that as a no op. Maybe we should just prevent 0
from being passed in.
For example if I do:
SELECT ST_AsText(ST_ConcaveHull(
ST_COLLECT(
array[
'POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))'::geometry, 'POLYGON((10
10, 11 10, 11 11, 10 11, 10 10))'::geometry
), 0.8
I get:
POLYGON((10 11,11 11,11 10,10 10,1 0,0 0,0 1,1 1,10 11))
and shows me visually what I would expect.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5781#comment:1>
