[PostGIS] #5781: Concave Hull returning multi poly with polygons
PostGIS trac at osgeo.org
Mon Sep 23 13:25:35 PDT 2024
  Reporter:  latot    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.4
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by latot):
 mmm, I did not test the percent, but probs will not fix it, testing the
 same example, while the ratio is lower then ~0.51 we will have a multi
 poly, is not exclusive of 0 ratio... D:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5781#comment:2>
