[PostGIS] #5782: XX000: Corrupted topology: adjacent edges 33 and -32 bind different face (1 and 0)
PostGIS trac at osgeo.org
Mon Sep 23 21:34:46 PDT 2024
and 0)
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  high               |  Milestone:  PostGIS 3.5.0
 Component:  postgis            |    Version:
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 When I test with 1e-05 I now see this this errors, there error below are
 also present with tolerance 1e-05
 XX000 message: SQL/MM Spatial exception - geometry crosses edge
 XX000 message: SQL/MM Spatial exception - end node not geometry end point.
 I try create testcase for this errors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:2>
