[PostGIS] #5782: XX000: Corrupted topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Mon Sep 23 22:24:26 PDT 2024
and 0)
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
It also fails on this
PostgreSQL 16.4 (Debian 16.4-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled
by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
Postgis 3.5.0dev - (3.5.0alpha2-55-g8349e1670) - 2024-09-23 05:55:28
scripts 3.5.0dev 3.5.0alpha2-55-g8349e1670
GEOS: 3.14.0dev-CAPI-1.20.0
PROJ: 9.5.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/local/share/proj/proj.db
pipeline here
[https://gitlab.com/nibioopensource/resolve-overlap-and-
gap/-/jobs/7900975113]
to run the test
time sh src/test/sql/regress/run_resolve_test.sh --nodrop
./src/test/sql/regress/topology_test_01.sql;
this test does not involve any code from
[https://gitlab.com/nibioopensource/resolve-overlap-and-gap]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:3>
