[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
PostGIS trac at osgeo.org
Tue Sep 24 02:53:33 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  high               |  Milestone:  PostGIS 3.5.0
 Component:  topology           |    Version:
Resolution:                     |   Keywords:
Comment (by strk):
 This query confirms edge 3 is found closer than edge 4:
 =# select edge_id, st_distance(geom, 'POINT(18.006691126034692
 69.04048768506776)') from t5782.edge order by geom <->
 'POINT(18.006691126034692 69.04048768506776)' limit 3;
  edge_id |      st_distance
        3 | 9.716835623092273e-05
        4 | 9.716835623285099e-05
        2 | 9.740220330897892e-05
 (3 rows)
 We don't even get an equidistance. On the other hand order by angle around
 nodes confirms edge 4 is on the left of edge 3. Puzzling.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:11>
