[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Tue Sep 24 02:58:32 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.0
Component: topology | Version:
Resolution: | Keywords:
Comment (by strk):
For the record: adding ONLY the point:
> select topogeo_addPoint('t5782', 'POINT(18.006691126034692
69.04048768506776)');
Sets `containing_face` of that point to 1, which is wrong, but
ValidateTopology will not notice because it will use the same algorithm
used during insertion to verify the face containing the point, so will
find again edge 3 being the closest edge it and thus consider the
containment valid. Maybe ValidateTopology should use a different method to
verify containment...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:12>
