[SCM] PostGIS branch master updated. 3.5.0rc1-7-g6140b4590
Wed Sep 25 11:13:56 PDT 2024
the project "PostGIS".
       via  6140b45906a25163fd3bffb575780c5afb3d6ab8 (commit)
       via  c8a5accf1cd64a4654d25e73a641e7e7ad763add (commit)
      from  ce50880e3b10900aa1670d75ae9ae3f0219c2baf (commit)
revisions in full, below.
commit 6140b45906a25163fd3bffb575780c5afb3d6ab8
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Sep 25 14:13:50 2024 -0400
    Prep for 3.5.0 release
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 73425e259..087913c4f 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
 How to release
-Date: 2022-08-08
+Date: 2022-09-25
 Versioning Scheme
@@ -86,7 +86,7 @@ Release procedure
 4. Update code.
   - Update the README.md to reflect new to be created buildbot badges
-	   (this should only be needed for trunk release)
+	   (this should only be needed for master release)
   - Edit README.postgis and set release date and version.
   - Add release notes in doc/release_notes.xml
   - Update Version.config to drop the "dev" suffix
diff --git a/NEWS b/NEWS
index 6ec175914..aac1e2297 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.5.0
-2024/09/xx
+2024/09/25
 To take advantage of all postgis_sfcgal extension features SFCGAL 1.5+ is needed.
 PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
diff --git a/README.postgis b/README.postgis
index 58b504d78..740c19207 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.5.0rc1
-:Date: 2024-09-22
+:Version: 3.5.0
+:Date: 2024-09-25
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 452e112b0..693b4f86e 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 5e4d545bf..20d013d4f 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-09-22 00:49+0000\n"
+"POT-Creation-Date: 2024-09-25 17:55+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -34448,7 +34448,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
 msgstr ""
 #. Tag: para
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 4b4c26caf..cb43d7e7c 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,7 +4,7 @@
     <subtitle>Release Notes</subtitle>
         <section>
             <title>PostGIS 3.5.0</title>
-            <para>2024/xx/xx</para>
+            <para>2024/09/25</para>
             <para>This version requires PostgreSQL 12-17, GEOS 3.8 or higher, and Proj 6.1+.
             To take advantage of all features, GEOS 3.12+ is needed.
             To take advantage of all SFCGAL features, SFCGAL 1.5.0+ is needed.</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 0321a58cf..f274b3b79 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -103,7 +103,6 @@ UPGRADEABLE_VERSIONS = \
 	3.4.0 \
 	3.4.1 \
 	3.4.2 \
-	3.4.3 \
-	3.5.0alpha2 \
-	3.5.0beta1 \
-	3.5.0rc1
+	3.4.3 \
+	3.5.0rc1 \
+	3.5.0dev
commit c8a5accf1cd64a4654d25e73a641e7e7ad763add
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Wed Sep 25 14:21:54 2024 +0200
    fix(doc): fix wrong deprecated warning CG_xxx is deprecated use CG_xxx
    Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/216
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index c45e2e5c9..b7adcffbc 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -913,12 +913,6 @@
     <refsection>
         <title>Description</title>
-        <warning>
-            <para>
-                <xref linkend="CG_3DDifference"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DDifference"/> instead.
-            </para>
-        </warning>
         <para>Returns that part of geom1 that is not part of geom2.</para>
         <para role="availability" conformance="3.5.0">Availability: 3.5.0</para>
         <para>&sfcgal_required;</para>
@@ -1427,13 +1421,6 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
-            <warning>
-                <para>
-                    <xref linkend="CG_3DUnion"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DUnion"/> instead.
-                </para>
-            </warning>
             <para>&sqlmm_compliant; SQL-MM IEC 13249-3: 5.1</para>
@@ -1886,12 +1873,6 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
-            <warning>
-                <para>
-                    <xref linkend="CG_ConstrainedDelaunayTriangles"/> is deprecated as of 3.5.0. Use <xref linkend="CG_ConstrainedDelaunayTriangles"/> instead.
-                </para>
-            </warning>
             <para>
                 Return a <link xlink:href="https://en.wikipedia.org/wiki/Constrained_Delaunay_triangulation">Constrained Delaunay
                 triangulation</link> around the vertices of the input geometry.
Summary of changes:
 HOWTO_RELEASE                       |  4 ++--
 NEWS                                |  2 +-
 README.postgis                      |  4 ++--
 Version.config                      |  2 +-
 doc/po/templates/postgis-manual.pot |  4 ++--
 doc/reference_sfcgal.xml            | 19 -------------------
 doc/release_notes.xml               |  2 +-
 extensions/upgradeable_versions.mk  |  7 +++----
 8 files changed, 12 insertions(+), 32 deletions(-)
hooks/post-receive
