[SCM] PostGIS branch master updated. 3.5.0rc1-8-g1fdb48514
git at osgeo.org
git at osgeo.org
Wed Sep 25 11:15:56 PDT 2024
the project "PostGIS".
via 1fdb48514c089b5f047da0a1e343d77afdafe8e2 (commit)
from 6140b45906a25163fd3bffb575780c5afb3d6ab8 (commit)
revisions in full, below.
commit 1fdb48514c089b5f047da0a1e343d77afdafe8e2
Author: Weblate <noreply at weblate.org>
Date: Wed Sep 25 18:14:13 2024 +0000
Update translation files
Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index c4e01f165..93b2f9088 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -8,7 +8,7 @@ msgid ""
msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-09-22 00:49+0000\n"
+"POT-Creation-Date: 2024-09-25 17:55+0000\n"
"PO-Revision-Date: 2024-02-26 08:45+0000\n"
"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -45174,7 +45174,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index bf1236989..c1013fdee 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -5,7 +5,7 @@ msgid ""
msgstr ""
"PO-Revision-Date: 2023-09-22 19:23+0000\n"
"Last-Translator: Anonymous <noreply at weblate.org>\n"
"Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -36606,7 +36606,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index e522252e2..3bfc4e0d1 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -7,7 +7,7 @@ msgid ""
msgstr ""
"PO-Revision-Date: 2024-06-18 14:45+0000\n"
"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -45031,7 +45031,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 5a6357b9b..4f8a342aa 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"PO-Revision-Date: 2023-12-15 20:10+0000\n"
"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -37154,7 +37154,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index a8b0534eb..0db623fc7 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -7,11 +7,11 @@ msgid ""
msgstr ""
"PO-Revision-Date: 2024-09-25 03:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -5385,7 +5385,8 @@ msgstr ""
msgid ""
"Adds a linestring to an existing topology using a tolerance and possibly "
"splitting existing edges/faces."
-msgstr "許容差を使って既存のトポロジにラインストリングを追加し、可能ならエッジ/フェイ"
+msgstr ""
+"許容差を使って既存のトポロジにラインストリングを追加し、可能ならエッジ/フェイ"
"スを分割します。"
#. Tag: para
@@ -5397,11 +5398,11 @@ msgid ""
"existing nodes or edges within given tolerance. Existing edges and faces may "
"be split by the line. New nodes and faces may be added."
msgstr ""
-"許容差を使って既存のトポロジにラインストリングを追加し、"
-"それを形成する符号付きエッジ識別子 (負符号は入力ラインストリングの逆方向に進"
-"む場合に付きます)の集合を返します。与えられたリンは既存のノードまたはエッジに"
-"指定した許容値内でスナップします。既存のエッジやフェイスはラインで分割される"
-"可能性があります。新しいノードとフェイスが追加される可能性があります。"
+"許容差を使って既存のトポロジにラインストリングを追加し、それを形成する符号付"
+"きエッジ識別子 (負符号は入力ラインストリングの逆方向に進む場合に付きます)の集"
+"合を返します。与えられたリンは既存のノードまたはエッジに指定した許容値内でス"
+"ナップします。既存のエッジやフェイスはラインで分割される可能性があります。新"
+"しいノードとフェイスが追加される可能性があります。"
#. Tag: para
#, no-c-format
@@ -33620,12 +33621,11 @@ msgid ""
"varname> is set to TRUE, then touched pixels are included, otherwise only if "
"the center of the pixel is in the geometry it is included."
msgstr ""
-"入力ジオメトリで切り取ったラスタを返します。バンドが指定されていない場合には"
-"、全てのバンドが処理されます。<varname>crop</"
-"varname>が指定されていなかったりTRUE となっている場合には、出力ラスタは切り取"
-"られます。<varname>touched</varname>がTRUEの場合には、接触するピクセルは取り"
-"込まれ、TRUEでない場合には、中心がジオメトリ内にあるピクセルだけが取り込まれ"
-"ます。"
+"入力ジオメトリで切り取ったラスタを返します。バンドが指定されていない場合に"
+"は、全てのバンドが処理されます。<varname>crop</varname>が指定されていなかった"
+"りTRUE となっている場合には、出力ラスタは切り取られます。<varname>touched</"
+"varname>がTRUEの場合には、接触するピクセルは取り込まれ、TRUEでない場合には、"
+"中心がジオメトリ内にあるピクセルだけが取り込まれます。"
#. Tag: para
#, no-c-format
@@ -42861,8 +42861,8 @@ msgstr "PostGIS 3.5.0"
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
-msgstr "2024/xx/xx"
+msgid "2024/09/25"
+msgstr ""
#. Tag: para
#, no-c-format
@@ -43045,7 +43045,8 @@ msgstr ""
msgid ""
"Zero length LineStrings are treated as if they are the equivalent Point "
"object."
-msgstr "長さが0のラインストリングは、等価なポイントオブジェクトとして扱われます。"
+msgstr ""
+"長さが0のラインストリングは、等価なポイントオブジェクトとして扱われます。"
#. Tag: title
#, no-c-format
@@ -49429,6 +49430,10 @@ msgstr "2.5次元/3次元対応"
msgid "Supports geography"
msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid "2024/xx/xx"
+#~ msgstr "2024/xx/xx"
#, no-c-format
#~ msgid ""
#~ "Adds a linestring to an existing topology using a tolerance and possibly "
diff --git a/doc/po/ka/postgis-manual.po b/doc/po/ka/postgis-manual.po
index 8c7ac0095..02f3d8130 100644
--- a/doc/po/ka/postgis-manual.po
+++ b/doc/po/ka/postgis-manual.po
@@ -4,7 +4,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"PO-Revision-Date: 2024-06-29 07:45+0000\n"
"Last-Translator: Temuri Doghonadze <temuri.doghonadze at gmail.com>\n"
"Language-Team: Georgian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -34450,7 +34450,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index fb2a537df..1b32398ef 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
msgstr ""
"PO-Revision-Date: 2023-10-14 20:23+0000\n"
"Language-Team: Korean <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -38997,7 +38997,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 435389ce3..32ba44c64 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
msgstr ""
"Language-Team: Polish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -34644,7 +34644,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index ad0f012f9..ef50ff7b9 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
msgstr ""
"Language-Team: Portuguese (Brazil) <https://weblate.osgeo.org/projects/"
@@ -39414,7 +39414,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index de71a6c7f..2328c37a4 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
msgstr ""
"Language-Team: Romanian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -34485,7 +34485,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 4405de560..878b92664 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
msgstr ""
"PO-Revision-Date: 2023-09-25 16:23+0000\n"
"Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -34502,7 +34502,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 57c4307fc..2e2c750fe 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
msgstr ""
"Language-Team: Ukrainian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -34452,7 +34452,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 8048afc54..e796eeccc 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
msgstr ""
"PO-Revision-Date: 2023-12-28 09:45+0000\n"
"Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
"Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
@@ -40441,7 +40441,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "2024/xx/xx"
+msgid "2024/09/25"
msgstr ""
#. Tag: para
Summary of changes:
doc/po/de/postgis-manual.po | 4 ++--
doc/po/es/postgis-manual.po | 4 ++--
doc/po/fr/postgis-manual.po | 4 ++--
doc/po/it_IT/postgis-manual.po | 4 ++--
doc/po/ja/postgis-manual.po | 41 ++++++++++++++++++++++------------------
doc/po/ka/postgis-manual.po | 4 ++--
doc/po/ko_KR/postgis-manual.po | 4 ++--
doc/po/pl/postgis-manual.po | 4 ++--
doc/po/pt_BR/postgis-manual.po | 4 ++--
doc/po/ro/postgis-manual.po | 4 ++--
doc/po/ru/postgis-manual.po | 4 ++--
doc/po/uk/postgis-manual.po | 4 ++--
doc/po/zh_Hans/postgis-manual.po | 4 ++--
13 files changed, 47 insertions(+), 42 deletions(-)
hooks/post-receive
