[SCM] PostGIS branch master updated. 3.5.0-1-gf8039ac1e
git at osgeo.org
git at osgeo.org
Wed Sep 25 12:33:26 PDT 2024
the project "PostGIS".
via f8039ac1e8e991c13988682be9ab03231819046c (commit)
from d2c3ca48e648571deda98d8e4d9bb4e2c82fde16 (commit)
revisions in full, below.
commit f8039ac1e8e991c13988682be9ab03231819046c
Author: Regina Obe <lr at pcorp.us>
Date: Wed Sep 25 15:33:20 2024 -0400
Start the new 3.6.0dev cycle
diff --git a/NEWS b/NEWS
index aac1e2297..4a66a90f3 100644
--- a/NEWS
+++ b/NEWS
@@ -1,103 +1,10 @@
-PostGIS 3.5.0
-2024/09/25
-To take advantage of all postgis_sfcgal extension features SFCGAL 1.5+ is needed.
-PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
-Many thanks to our translation teams, in particular:
-Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
-Teramoto Ikuhiro (Japanese Team)
-Andreas Schild (German Team)
+PostGIS 3.6.0
+2025/xx/xx
* Breaking Changes *
- - #5546, TopoGeometry <> TopoGeometry is now ambiguous, to get
- the old behaviour, assuming your TopoGeometry objects
- are named tg1 and tg2, use: (
- id(tg1) <> id(tg2) OR
- topology_id(tg1) <> topology_id(tg2) OR
- layer_id(tg1) <> layer_id(tg2) OR
- type(tg1) <> type(tg2)
- ) (Sandro Santilli)
- - #5536, comments are not anymore included in PostGIS extensions
- (Sandro Santilli)
- - xmllint is now required to build comments (Sandro Santilli)
- - DocBook5 XSL is now required to build html (Sandro Santilli)
- - #5602, Drop support for GEOS 3.6 and 3.7 (Regina Obe)
- - #5571, Improve ST_GeneratePoints performance, but old
- seeded pseudo random points will need to be regenerated.
- - #5596, GH-749, Allow promoting column as an id
- in ST_AsGeoJson(record,..).
- Views and materialized views that use the ST_AsGeoJSON(record ..)
- will need rebuilding to upgrade to new signature
- (Jan Tojnar)
- - #5496, ST_Clip all variants replaced, will require
- rebuilding of materialized views that use them (Regina Obe)
- - #5659, ST_DFullyWithin behaviour has changed to
- be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)
- - Remove the WFS_locks extra package. (Paul Ramsey)
- - #5747, GH-776, ST_Length: Return 0 for CurvePolygon (Dan Baston)
- - #5770, support for GEOS 3.13 and RelateNG. Most functionality
- remains the same, but new GEOS predicate implementation
- has a few small changes.
- - Boundary Node Rule relate matrices might be different when
- using the "multi-valent end point" rule.
- - Relate matrices for situations with invalid MultiPolygons
- with shared boundaries might be different. Run ST_MakeValid
- to get valid inputs to feed to the calculation.
- - Zero length LineStrings are treated as if they are the
- equivalent Point object.
* Deprecated signatures *
- - GH-761, ST_StraightSkeleton => CG_StraightSkeleton (Loïc Bartoletti)
- - GT-189, All SFCGAL functions now use the prefix CG_, with the old onesusing
- ST_ being deprecated. (Loïc Bartoletti)
* New Features *
- - Improvements in the 'postgis' script:
- - new command list-enabled
- - new command list-all
- - command upgrade upgrades all databases that need to be
- - command status reports status of all databases
- (Sandro Santilli)
- - #5742, expose version of PROJ at compile time (Sandro Santilli)
- - #5721, postgis_topology: Allow sharing sequences between different topologies (Lars Opsahl)
- - #5667, postgis_topology: TopoGeo_LoadGeometry (Sandro Santilli)
- - #5055, add explicit <> geometry operator to prevent non-unique
- error with <> and != (Paul Ramsey)
- - Add ST_HasZ/ST_HasM (Loïc Bartoletti)
- - GT-123, postgis_sfcgal: CG_YMonotonePartition, CG_ApproxConvexPartition,
- CG_GreeneApproxConvexPartition and CG_OptimalConvexPartition
- (Loïc Bartoletti)
- - GT-156, postgis_sfcgal: CG_Visibility (Loïc Bartoletti)
- - GT-157, postgis_sfcgal: Add ST_ExtrudeStraightSkeleton (Loïc Bartoletti)
- - #5496, postgis_raster: ST_Clip support for touched (Regina Obe)
- - GH-760, postgis_sfcgal: CG_Intersection, CG_3DIntersects, CG_Intersects,
- CG_Difference, CG_Union (and aggregate), CG_Triangulate, CG_Area,
- CG_3DDistance, CG_Distance (Loïc Bartoletti)
- - #5687, Don't rely on search_path to determine postgis schema
- Fix for PG17 security change (Regina Obe)
- - #5705, GH-767, ST_RemoveIrrelevantPointsForView (Sam Peters)
- - #5706, GH-768, ST_RemoveSmallParts (Sam Peters)
-* Enhancements *
- - #5550, Fix upgrades from 2.x in sandboxed systems (Sandro Santilli)
- - #3587, postgis_topology: faster load of big lines in topologies (Sandro Santilli)
- - #5670, postgis_topology: faster ST_CreateTopoGeo (Sandro Santilli)
- - #5531, documentation format upgraded to DocBook 5 (Sandro Santilli)
- - #5543, allow building without documentation (Sandro Santilli)
- in ST_AsGeoJson(record,..). (Jan Tojnar)
- - GH-744, Don't create docbook.css for the HTML manual,
- use style.css instead (Chris Mayo)
- - Faster implementation of point-in-poly cached index (Paul Ramsey)
- - Improve performance of ST_GeneratePoints (Paul Ramsey)
- - #5361, ST_CurveN, ST_NumCurves and consistency in
- accessors on curved geometry (Paul Ramsey)
- - GH-761, postgis_sfcgal: Add an optional parameter to CG_StraightSkeleton
- (was ST_StraightSkeleton) to use m as a distance in result (Hannes Janetzek, Loïc Bartoletti)
diff --git a/Version.config b/Version.config
index 693b4f86e..cf6d63e9f 100644
--- a/Version.config
+++ b/Version.config
@@ -4,8 +4,8 @@
# See HOWTO_RELEASE file in SVN for definitions of those three.
POSTGIS_MAJOR_VERSION=3
-POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=0
+POSTGIS_MINOR_VERSION=6
+POSTGIS_MICRO_VERSION=0dev
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index cb43d7e7c..e5473ae25 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,115 +3,8 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<section>
- <title>PostGIS 3.5.0</title>
- <para>2024/09/25</para>
- <para>This version requires PostgreSQL 12-17, GEOS 3.8 or higher, and Proj 6.1+.
- To take advantage of all features, GEOS 3.12+ is needed.
- To take advantage of all SFCGAL features, SFCGAL 1.5.0+ is needed.</para>
- <para>Many thanks to our translation teams, in particular:</para>
- <para>Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)</para>
- <para>Teramoto Ikuhiro (Japanese Team)</para>
- <para>Vincent Bre (French Team)</para>
- <simplesect>
- <title>Breaking Changes</title>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5546">#5546</link>, TopoGeometry <> TopoGeometry is now ambiguous, to get
- ) (Sandro Santilli)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5536">#5536</link>, comments are not anymore included in PostGIS extensions
- (Sandro Santilli)</para>
-<para>xmllint is now required to build comments (Sandro Santilli)</para>
-<para>DocBook5 XSL is now required to build html (Sandro Santilli)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5602">#5602</link>, Drop support for GEOS 3.6 and 3.7 (Regina Obe)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5571">#5571</link>, Improve ST_GeneratePoints performance, but old
- seeded pseudo random points will need to be regenerated.</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5596">#5596</link>, GH-749, Allow promoting column as an id
- (Jan Tojnar)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5496">#5496</link>, ST_Clip all variants replaced, will require
- rebuilding of materialized views that use them (Regina Obe)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5659">#5659</link>, ST_DFullyWithin behaviour has changed to
- be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)</para>
-<para>Remove the WFS_locks extra package. (Paul Ramsey)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5747">5747</link>, <link xlink:href="https://github.com/postgis/postgis/pull/776">GH-776</link>, ST_Length: Return 0 for CurvePolygon (Dan Baston)</para>
-<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5770">5770</link>, support for GEOS 3.13 and RelateNG. Most functionality
- has a few small changes.</para>
- <para>Boundary Node Rule relate matrices might be different when
- using the "multi-valent end point" rule.</para>
- <para>Relate matrices for situations with invalid MultiPolygons
- to get valid inputs to feed to the calculation.</para>
- <para>Zero length LineStrings are treated as if they are the
- equivalent Point object.</para>
- </simplesect>
- <simplesect><title>Deprecated signatures</title>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/761">GH-761</link>, ST_StraightSkeleton => CG_StraightSkeleton (Loïc Bartoletti)</para>
- <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/189">GH-189</link>, All SFCGAL functions now use the prefix CG_, with the old ones using
- ST_ being deprecated. (Loïc Bartoletti)</para>
- </simplesect>
- <simplesect>
- <title>New features</title>
- <para>Improvements in the 'postgis' script:
- <itemizedlist>
- <listitem><para>new command list-enabled</para></listitem>
- <listitem><para>new command list-all</para></listitem>
- <listitem><para>command upgrade upgrades all databases that need to be</para></listitem>
- <listitem><para>command status reports status of all databases</para></listitem>
- </itemizedlist>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5742">#5742</link>, expose version of PROJ at compile time (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5721">#5721</link>, postgis_topology: Allow sharing sequences between different topologies (Lars Opsahl)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5667">#5667</link>, postgis_topology: TopoGeo_LoadGeometry (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5055">#5055</link>, add explicit <> geometry operator to prevent non-unique
- error with <> and != (Paul Ramsey)</para>
- <para>Add ST_HasZ/ST_HasM (Loïc Bartoletti)</para>
- <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/123">GT-123</link>, postgis_sfcgal: CG_YMonotonePartition, CG_ApproxConvexPartition,
- (Loïc Bartoletti)</para>
- <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/156">GT-156</link>, postgis_sfcgal: CG_Visibility (Loïc Bartoletti)</para>
- <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/157">GT-157</link>, postgis_sfcgal: Add ST_ExtrudeStraightSkeleton (Loïc Bartoletti)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5496">#5496</link>, postgis_raster: ST_Clip support for touched (Regina Obe)</para>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/760">GH-760</link>, postgis_sfcgal: CG_Intersection, CG_3DIntersects, CG_Intersects,
- CG_3DDistance, CG_Distance (Loïc Bartoletti)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5687">#5687</link>, Don't rely on search_path to determine postgis schema
- Fix for PG17 security change (Regina Obe)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5705">#5705</link>, <link xlink:href="https://github.com/postgis/postgis/pull/767">GH-767</link>, ST_RemoveIrrelevantPointsForView (Sam Peters)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5706">#5706</link>, <link xlink:href="https://github.com/postgis/postgis/pull/768">GH-768</link>, ST_RemoveSmallParts (Sam Peters)</para>
- </simplesect>
- <simplesect>
- <title>Enhancements</title>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5550">5550</link>, Fix upgrades from 2.x in sandboxed systems (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3587">#3587</link>, postgis_topology: faster load of big lines in topologies (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5670">#5670</link>, postgis_topology: faster ST_CreateTopoGeo (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5531">#5531</link>, documentation format upgraded to DocBook 5 (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5543">#5543</link>, allow building without documentation (Sandro Santilli)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5596">#5596</link>, <link xlink:href="https://github.com/postgis/postgis/pull/749">GH-749</link>, Allow promoting column as an id
- in ST_AsGeoJson(record,..). (Jan Tojnar)</para>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/744">GH-744</link>, Don't create docbook.css for the HTML manual,
- use style.css instead (Chris Mayo)</para>
- <para>Faster implementation of point-in-poly cached index (Paul Ramsey)</para>
- <para>Improve performance of ST_GeneratePoints (Paul Ramsey)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5361">#5361</link>, ST_CurveN, ST_NumCurves and consistency in
- accessors on curved geometry (Paul Ramsey)</para>
- <para><link xlink:href="https://github.com/postgis/postgis/pull/761">GH-761</link>, postgis_sfcgal: Add an optional parameter to CG_StraightSkeleton
- (was ST_StraightSkeleton) to use m as a distance in result (Hannes Janetzek, Loïc Bartoletti)</para>
- </simplesect>
- </section>
+ <title>PostGIS 3.6.0</title>
+ <para>2025/xx/xx</para>
+ </section>
</appendix>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 93dd7f756..8223e1631 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -104,5 +104,5 @@ UPGRADEABLE_VERSIONS = \
3.4.1 \
3.4.2 \
3.4.3 \
- 3.5.0rc1 \
- 3.5.0dev
+ 3.4.4dev \
+ 3.5.0
Summary of changes:
NEWS | 97 +------------------------------
Version.config | 4 +-
doc/release_notes.xml | 113 +------------------------------------
extensions/upgradeable_versions.mk | 4 +-
4 files changed, 9 insertions(+), 209 deletions(-)
hooks/post-receive
