[PostGIS] #5783: PostGIS 3.6 regress failure on sfcgal deprecation notices
PostGIS trac at osgeo.org
Wed Sep 25 12:55:11 PDT 2024
 Reporter:  robe     |      Owner:  lbartoletti
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.6.0
Component:  sfcgal   |    Version:  master
 Keywords:           |
 I just flipped the switch to start the 3.6 dev cycle, and so the
 regression tests on sfcgal need changing
 +WARNING:  ST_ForceLHR signature was deprecated in 3.5.0. Please use
 CG_ForceLHR
 +WARNING:  ST_Orientation signature was deprecated in 3.5.0. Please use
 CG_Orientation
  ST_Orientation_1|-1
 CG_Orientation
  ST_Orientation_2|1
 +WARNING:  ST_MinkowskiSum signature was deprecated in 3.5.0. Please use
 CG_MinkowsikSum
  ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
 +WARNING:  ST_ConstrainedDelaunayTriangles signature was deprecated in
 3.5.0. Please use CG_ConstrainedDelaunayTriangles
  ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2
 2)))
 +WARNING:  ST_3DConvexHull signature was deprecated in 3.5.0. Please use
 CG_3DConvexHull
 +WARNING:  ST_3DArea signature was deprecated in 3.5.0. Please use
 CG_3DArea
  ST_3DConvexHull|80.9227
 +WARNING:  ST_Extrude signature was deprecated in 3.5.0. Please use
 CG_Extrude
 CG_Extrude
 +WARNING:  ST_3DUnion signature was deprecated in 3.5.0. Please use
 CG_3DUnion
 +WARNING:  ST_Volume signature was deprecated in 3.5.0. Please use
 CG_Volume
  ST_3DUnion|t
 CG_Extrude
 CG_Extrude
 CG_Volume
  ST_3DUnion (aggregate)|t
  CG_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0
 1,0 0,1 0,0 1))))
  CG_3DArea|1
  sfcgal/regress/approximatemedialaxis .. failed (diff expected obtained:
 /tmp/pgis_reg/test_170_diff)
 --- ./sfcgal/regress/approximatemedialaxis_expected     2024-09-25
 19:33:42.477404521 +0000
 +++ /tmp/pgis_reg/test_170_out  2024-09-25 19:35:22.527722829 +0000
 @@ -1,2 +1,4 @@
 +WARNING:  ST_ApproximateMedialAxis signature was deprecated in 3.5.0.
 Please use CG_ApproximateMedialAxis
  square|SRID=3857;MULTILINESTRING EMPTY
  rect1|SRID=4326;MULTILINESTRING((0.5 0.5,1.5 0.5))
  sfcgal/regress/alphashape .. failed (diff expected obtained:
 /tmp/pgis_reg/test_171_diff)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5783>
