[PostGIS] #5689: Set PostGIS windows bundle environment for service rather than machine.
PostGIS trac at osgeo.org
Fri Sep 27 21:28:09 PDT 2024
  Reporter:  slefranc     |      Owner:  robe
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS Packaging
 Component:  install      |    Version:  3.4.x
Resolution:               |   Keywords:  windows
Comment (by robe):
 Replying to [comment:6 mdruve]:
 > Hey,
 > when you are already working on the installer script, can I maybe add to
 please add the removal of the environment variables to the uninstaller
 part, too.
 > Because when the postgis bundle gets uninstalled, the environment
 variables won't be removed. That's bad for the rest of the system,
 especially the CURL_CA_BUNDLE variable will point to a path which won't
 exist after the uninstallation and other programs will stop working
 completely because of the missing CA stuff.
 > My used PC installer system OPSI is one of them, because their client
 agent stops working completely. So nothing can be installed or uninstalled
 anymore.
 > I have to remove that environment variable by hand before it is working
 again.
 > For now, I will add the removal of these variables in my own
 uninstallation script part for this postgis bundle, and I'm good.
 > But it would be nice if this get fixed in the long run.
 > Thanks in advance
 Working on the scripts now.  Will try to do.  If you have something
 already prepared, feel free to attach a patch for it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5689#comment:7>
