[PostGIS] #5689: Set PostGIS windows bundle environment for service rather than machine.
PostGIS trac at osgeo.org
Sat Sep 28 20:39:20 PDT 2024
  Reporter:  slefranc     |      Owner:  robe
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS Packaging
 Component:  install      |    Version:  3.4.x
Resolution:               |   Keywords:  windows
Comment (by robe):
 I put up the installer for PG17 PostGIS 3.5.0 and have it remove the
 CURL_CA_BUNDLE, GDAL_DATA, PROJ_LIB if it matches what was installed.
 I'm keeping this ticket open since I haven't had a chance to try putting
 these under the PostgreSQL services.  If I do I'll probably do a rerelease
 of PG17 PostGIS 3.5.0.
 I'm going to try a bit on that for the PG13-PG16 releases and if I am
 successful will have those be under services, and if not successful, just
 do the same as I did for PG17.
 Installer source file here -
 https://download.osgeo.org/postgis/windows/source/pg17/
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5689#comment:8>
