[PostGIS] #5874: ST_LineSubstring returns incorrect lengths in geography
    trac at osgeo.org
    Tue Apr  1 00:18:56 PDT 2025
 Reporter:  jorsu                          |      Owner:  pramsey
     Type:  defect                         |     Status:  new
 Priority:  blocker                        |  Milestone:  PostGIS 3.5.3
Component:  postgis                        |    Version:  3.5.x
 Keywords:  linestring, geography, length  |
 I am encountering an issue with the {{{ST_LineSubstring}}} function. The
 results remain inconsistent when applying on a {{{geography}}}type.
 I am running:
 PostgreSQL 17.4 (Debian 17.4-1.pgdg110+2) on x86_64-pc-linux-gnu, compiled
 by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
 POSTGIS="3.5.2 dea6d0a" [EXTENSION] PGSQL="170" GEOS="3.9.0-CAPI-1.16.2"
 PROJ="7.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
 DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 7.2.1)
 GDAL="GDAL 3.2.2, released 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
 I am trying to:
 - Extract a subline from a {{{LINESTRING}}}.
 - Accurately measure its length in the {{{geography}}} type.
 However, when using {{{ST_LineSubstring}}} directly on a {{{geography}}}
 type, the resulting length is incorrect and does not match the expected
 value.
 Here is a minimal reproducible example:
 WITH
     "path" AS (
         SELECT ST_SetSRID(ST_GeomFromText('LINESTRING(2.3522 48.8566,
 2.3535 48.8570, 2.3548 48.8580, 2.3561 48.8590, 2.3574 48.8600)'), 4326)
 AS path
 SELECT
     ST_Length(p."path"::geography) full_length,
     ST_Length(
          ST_LineSubstring(p."path"::geometry, 0, 1)::geography
     ) geom_length,
     ST_Length(
          ST_LineSubstring(p."path"::geography, 0, 1)::geography
     ) geog_length
 from "path" p;
 This query returns:
    full_length         geom_length         geog_length
 544.8029520664281   544.8029520664281   324.1448393269909
 Why does {{{ST_LineSubstring}}} on a {{{geography}}} type produce a
 different length than the same operation on a geometry type and the
 original path?
 Is this a known issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5874>
