[SCM] PostGIS branch master updated. 3.5.0-242-g3bc774786
git at osgeo.org
git at osgeo.org
Thu Apr 3 05:50:02 PDT 2025
the project "PostGIS".
via 3bc774786e6b6b1c501681f96b59b4ac3784f3b8 (commit)
from 8bce1d21888fdf5925f1278aba88b9d3e5767cdd (commit)
revisions in full, below.
commit 3bc774786e6b6b1c501681f96b59b4ac3784f3b8
Author: Regina Obe <lr at pcorp.us>
Date: Thu Apr 3 08:49:56 2025 -0400
Add danish to woodpecker testing
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 301cd4bf3..2741b0ce2 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -175,6 +175,18 @@ steps:
include:
- "doc/po/ko_KR/*.po"
+ check-xml-da:
+ image: *test_image
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/da local-check-xml
+ depends_on: prepare
+ when:
+ - event: push
+ path:
+ include:
+ - "doc/po/da/*.po"
check-xml-de:
image: *test_image
pull: true
@@ -332,6 +344,18 @@ steps:
include:
+ html-da:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/da local-html
+ depends_on: check-xml-da
+ when:
+ - event: push
+ path:
+ include:
html-de:
image: *test_image
pull: true
@@ -489,6 +513,18 @@ steps:
include:
+ cheatsheets-da:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/da local-cheatsheets
+ when:
+ - event: push
+ path:
+ include:
cheatsheets-de:
image: *test_image
pull: true
@@ -646,6 +682,18 @@ steps:
include:
+ check-cheatsheets-da:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/da local-check-cheatsheets
+ depends_on: [ cheatsheets-da, build-cheatsheets ]
+ when:
+ - event: push
+ path:
+ include:
check-cheatsheets-de:
image: *test_image
pull: true
@@ -803,6 +851,18 @@ steps:
include:
+ pdf-da:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/da local-pdf
+ depends_on: [ build-images, check-xml-da ]
+ when:
+ - event: push
+ path:
+ include:
pdf-de:
image: *test_image
pull: true
Summary of changes:
.woodpecker/docs.yml | 60 ++++++++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 60 insertions(+)
hooks/post-receive
