[SCM] PostGIS branch master updated. 3.5.0-246-gd6031ec0d
git at osgeo.org
git at osgeo.org
Mon Apr 7 13:11:46 PDT 2025
the project "PostGIS".
via d6031ec0d52dec2886989f6bedc52e35e332a59f (commit)
via 94186341879a6c388c90a63aaf73c19001be0e7c (commit)
from 9388d6fd79d5f9b4ea37b0c79d54957b9deb2741 (commit)
revisions in full, below.
commit d6031ec0d52dec2886989f6bedc52e35e332a59f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Apr 7 13:11:41 2025 -0700
Apply Cirrus updates from loic.bartoletti at oslandia.com
diff --git a/.cirrus.yml b/.cirrus.yml
index c2490f510..d6eafbf66 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -1,95 +1,114 @@
task:
- only_if: $CIRRUS_BRANCH =~ 'pull/.*'
+ # only_if: $CIRRUS_BRANCH =~ 'pull/.*'
alias: test-freebsd
- #env:
- #MAKE_FLAGS: -j 8
- install_script:
- - sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
- - ASSUME_ALWAYS_YES=yes pkg bootstrap -f
- - pkg install -y
- autoconf
- automake
- bison
- cunit
- docbook
- gdal
- geos
- gmake
- iconv
- json-c
- libtool
- libxml2
- libxslt
- pcre
- pkgconf
- postgresql13-contrib
- postgresql13-server
- proj
- protobuf-c
- sfcgal
- - projsync --system-directory --source-id us_noaa
- - projsync --system-directory --source-id ch_swisstopo
+ env:
+ CIRRUS_CLONE_DEPTH: 1
+ CCACHE_DIR: "/tmp/ccache_dir"
+ NCPU: 8
+ MAKEJOBS: "-j${NCPU}"
+ CC: "ccache clang"
+ CXX: "ccache clang++"
+ CCACHE_MAXSIZE: 1
+ CCACHE_COMPRESS: 1
+ CCACHE_STATIC_PREFIX: "/usr/local"
+ CCACHE_NOSTATS: 1
+ CCACHE_TEMPDIR: "/tmp"
+ BASEFS: "${CIRRUS_WORKING_DIR}/test_bulk"
+ freebsd_cache:
+ folder: ${CCACHE_DIR}
+ pkg_bootstrap_script:
+ sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
+ ASSUME_ALWAYS_YES=yes pkg bootstrap -f
+ pkg_cache:
+ folder: /var/cache/pkg
+ populate_script:
+ pkg fetch -udy autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pcre2 pkgconf postgresql13-contrib postgresql13-server proj protobuf-c sfcgal
+ install_pkgs_script:
+ env IGNORE_OSVERSION=yes pkg update -f
+ env IGNORE_OSVERSION=yes pkg install -y autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pcre2 pkgconf postgresql13-contrib postgresql13-server proj protobuf-c sfcgal
+ projsync --system-directory --source-id us_noaa
+ projsync --system-directory --source-id ch_swisstopo
+ ccache_setup_script:
+ env IGNORE_OSVERSION=yes pkg install -y ccache-static
+ ccache --max-size=${CCACHE_MAXSIZE}
patch_script:
- # will be removed
- - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
+ find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
build_script:
- - ./autogen.sh
- - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --with-topology --without-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
- - service postgresql oneinitdb
- - service postgresql onestart
- - su postgres -c "createuser -s `whoami`"
- - gmake || { service postgresql onestop; exit 1;}
- - gmake check RUNTESTFLAGS="-v" || { service postgresql onestop; exit 1;}
- - gmake install || { service postgresql onestop; exit 1;}
- - gmake check RUNTESTFLAGS="-v --extension" || { service postgresql onestop; exit 1;}
- - gmake check RUNTESTFLAGS="-v --extension --dumprestore" || { service postgresql onestop; exit 1;}
- - service postgresql onestop
+ ./autogen.sh
+ ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --with-topology --without-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
+ service postgresql oneinitdb
+ service postgresql onestart
+ su postgres -c "createuser -s `whoami`"
+ gmake ${MAKEJOBS} || { service postgresql onestop; exit 1; }
+ gmake ${MAKEJOBS} install || { service postgresql onestop; exit 1; }
+ ccache -s
+ test_script:
+ gmake ${MAKEJOBS} check RUNTESTFLAGS="-v --extension --dumprestore" || { service postgresql onestop; exit 1; }
+ service postgresql onestop
freebsd_instance:
- cpu: 8
- memory: 24g
+ cpu: ${NCPU}
+ memory: 24G
matrix:
- # - name: 14-CURRENT
- # freebsd_instance:
- # image_family: freebsd-14-0-snap
- - name: 13.2-RELEASE
+ - name: 14.2-RELEASE
freebsd_instance:
- image_family: freebsd-13-2
+ image_family: freebsd-14-2
task:
alias: test-macos
- test_script:
- - brew update
- - brew install
- autoconf
- automake
- cunit
- docbook
- docbook-xsl
- gdal
- geos
- gpp
- json-c
- libtool
- pcre2
- pkg-config
- postgresql at 14
- proj
- sfcgal
- - ./autogen.sh
- - ./configure --without-gui --without-interrupt-tests --without-topology --without-raster --with-sfcgal --with-address-standardizer --without-protobuf --with-pgconfig=/opt/homebrew/opt/postgresql at 14/bin/pg_config
- - brew services start postgresql at 14
- - postgres -V
- - make -j8 || { brew services stop postgresql at 14; exit 1;}
- - make -j8 check || { brew services stop postgresql at 14; exit 1;}
- - brew services stop postgresql at 14
+ macos_instance:
+ image: ghcr.io/cirruslabs/macos-runner:sonoma
- matrix:
- macos_instance:
- image: ghcr.io/cirruslabs/macos-ventura-base:latest
- # macos_instance:
- # image: ghcr.io/cirruslabs/macos-monterey-base:latest
+ env:
+ CCACHE_DIR: "$HOME/.ccache"
+ CCACHE_MAXSIZE: 1
+ PG: "17"
+ HOMEBREW_PREFIX: "/opt/homebrew"
+ PATH: "${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin:${HOMEBREW_PREFIX}/bin:${HOMEBREW_PREFIX}/sbin:${HOMEBREW_PREFIX}/opt/ccache/libexec:$PATH"
+ setup_script:
+ brew update
+ brew install ccache autoconf automake libtool pkg-config gdal geos icu4c json-c libpq libxml2 pcre2 proj protobuf-c sfcgal cunit docbook docbook-xsl postgresql@${PG} gettext
+ brew link --force gettext
+ ccache --max-size=$CCACHE_MAXSIZE
+ sudo ln -sfn ${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/postgres /usr/local/bin/postgres
+ test_script:
+ export PGCONFIG="${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/pg_config"
+ export CFLAGS="-I${HOMEBREW_PREFIX}/opt/gettext/include \
+ -I${HOMEBREW_PREFIX}/opt/postgresql@${PG}/include \
+ -I${HOMEBREW_PREFIX}/include -Wno-nullability-completeness"
+ export LDFLAGS="-L${HOMEBREW_PREFIX}/opt/gettext/lib \
+ -L${HOMEBREW_PREFIX}/opt/postgresql@${PG}/lib"
+ export CXXFLAGS="-std=c++17"
+ ./autogen.sh
+ ./configure --without-gui \
+ --without-interrupt-tests \
+ --with-topology \
+ --without-raster \
+ --with-sfcgal \
+ --with-address-standardizer \
+ --with-protobuf \
+ --with-pgconfig=${PGCONFIG}
+ brew services start postgresql@${PG}
+ make -j$(sysctl -n hw.logicalcpu) || { brew services stop postgresql@${PG}; exit 1; }
+ make -j$(sysctl -n hw.logicalcpu) check || { brew services stop postgresql@${PG}; exit 1; }
+ brew services stop postgresql@${PG}
+ macos_cache:
+ folders: ${CCACHE_DIR}
+ upload_caches: macos
commit 94186341879a6c388c90a63aaf73c19001be0e7c
Date: Mon Apr 7 12:28:45 2025 -0700
Fix ST_AddPoint with empty point argument
References #5876
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index b51a65d75..c75bbb6ca 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -107,7 +107,8 @@ POINT4D
getPoint4d(const POINTARRAY *pa, uint32_t n)
POINT4D result;
- getPoint4d_p(pa, n, &result);
+ if (getPoint4d_p(pa, n, &result) == 0)
+ lwerror("%s [%d] error returned by getPoint4d_p", __FILE__, __LINE__);
return result;
@@ -134,7 +135,7 @@ getPoint4d_p(const POINTARRAY *pa, uint32_t n, POINT4D *op)
if ( n>=pa->npoints )
- LWDEBUGF(2, "%s [%d] called with n=%d and npoints=%d", __FILE__, __LINE__, n, pa->npoints);
+ lwerror("%s [%d] called with n=%d and npoints=%d", __FILE__, __LINE__, n, pa->npoints);
return 0;
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 1f9348c1b..974fad631 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2294,6 +2294,11 @@ Datum LWGEOM_addpoint(PG_FUNCTION_ARGS)
PG_RETURN_NULL();
+ if (gserialized_is_empty(pglwg2))
+ PG_RETURN_POINTER(pglwg1);
line = lwgeom_as_lwline(lwgeom_from_gserialized(pglwg1));
if (PG_NARGS() <= 2)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 913970d4b..9ac1f216b 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1575,3 +1575,7 @@ WHERE ST_DFullyWithin(
extent,
1700
+SELECT '#5876', ST_AsText(ST_AddPoint(
+ 'LINESTRING (1 1, 2 2)'::geometry,
+ 'POINT EMPTY'::geometry), 2);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 27d415dba..d18abe567 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -483,3 +483,4 @@ ERROR: Geometry contains invalid coordinates
#5686|0
#5747|0
#5855|Knosesmauet
+#5876|LINESTRING(1 1,2 2)
Summary of changes:
.cirrus.yml | 181 +++++++++++++++++++++------------------
liblwgeom/lwgeom_api.c | 5 +-
postgis/lwgeom_functions_basic.c | 5 ++
regress/core/tickets.sql | 4 +
regress/core/tickets_expected | 1 +
5 files changed, 113 insertions(+), 83 deletions(-)
hooks/post-receive
