[SCM] PostGIS branch stable-3.5 updated. 3.5.2-15-gb5f353eb2
Tue Apr 8 14:14:35 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  b5f353eb264a11cf9eb63af5eed63ac47c2b4774 (commit)
      from  9024a3732d942893e92f85e4986f05da8773fda5 (commit)
revisions in full, below.
commit b5f353eb264a11cf9eb63af5eed63ac47c2b4774
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 8 14:14:15 2025 -0700
    Don't skip the last point in doing
    linestring substring for geography,
    References #5874
diff --git a/NEWS b/NEWS
index a8c35ebe8..9a0f46525 100644
--- a/NEWS
+++ b/NEWS
@@ -12,7 +12,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
 - #5819, Support longer names in estimated extent (Paul Ramsey)
 - Fix misassignment of result in _lwt_HealEdges (Maxim Korotkov)
 - #5876, ST_AddPoint with empty argument adds garbage (Paul Ramsey)
+- #5874, Line substring returns wrong answer (Paul Ramsey)
 PostGIS 3.5.2
diff --git a/liblwgeom/cunit/cu_geodetic.c b/liblwgeom/cunit/cu_geodetic.c
index 4d5656b17..99651aa52 100644
--- a/liblwgeom/cunit/cu_geodetic.c
+++ b/liblwgeom/cunit/cu_geodetic.c
@@ -1594,6 +1594,53 @@ static void test_lwgeom_area_sphere(void)
+static void test_geography_substring(void)
+	LWGEOM *lwg;
+	LWGEOM *result;
+	double length;
+	SPHEROID s;
+	/* Init to Sphere */
+	spheroid_init(&s, WGS84_RADIUS, WGS84_RADIUS);
+	s.a = s.b = s.radius;
+	 * geography_substring(
+	 *   const LWLINE *lwline,
+	 *   const SPHEROID *s,
+	 *   double from, double to, double tolerance
+	lwg = lwgeom_from_wkt("LINESTRING(2 48, 2 49, 2 50)", LW_PARSER_CHECK_NONE);
+	length = lwgeom_length(lwg);
+	CU_ASSERT_DOUBLE_EQUAL(length, 2.0, 0.001);
+	result = geography_substring((LWLINE*)lwg, &s, 0.0, 1.0, 0.01);
+	length = lwgeom_length(result);
+	lwgeom_free(lwg);
+	lwgeom_free(result);
+	lwg = lwgeom_from_wkt("LINESTRING(2 48, 2 49)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_DOUBLE_EQUAL(length, 1.0, 0.001);
+	lwgeom_free(lwg);
+	lwg = lwgeom_from_wkt("LINESTRING(2 48)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_DOUBLE_EQUAL(length, 0.0, 0.001);
+	lwgeom_free(lwg);
 static void test_gbox_to_string_truncated(void)
 	GBOX g = {
@@ -1682,4 +1729,5 @@ void geodetic_suite_setup(void)
 	PG_ADD_TEST(suite, test_ptarray_contains_point_sphere_iowa);
 	PG_ADD_TEST(suite, test_gbox_to_string_truncated);
 	PG_ADD_TEST(suite, test_gbox_geocentric_get_gbox_cartesian);
+	PG_ADD_TEST(suite, test_geography_substring);
diff --git a/liblwgeom/lwgeodetic_measures.c b/liblwgeom/lwgeodetic_measures.c
index 1bca0a795..8c2bca596 100644
--- a/liblwgeom/lwgeodetic_measures.c
+++ b/liblwgeom/lwgeodetic_measures.c
@@ -232,6 +232,7 @@ geography_substring(
 	END:
 		tlength += slength;
 		memcpy(&p1, &p2, sizeof(POINT4D));
+		geographic_point_init(p1.x, p1.y, &g1);
 	if (dpa->npoints <= 1) {
Summary of changes:
 NEWS                            |  2 +-
 liblwgeom/cunit/cu_geodetic.c   | 48 +++++++++++++++++++++++++++++++++++++++++
 liblwgeom/lwgeodetic_measures.c |  1 +
 3 files changed, 50 insertions(+), 1 deletion(-)
hooks/post-receive
