[SCM] PostGIS branch master updated. 3.5.0-254-g5ae253cb6
    git at osgeo.org
    git at osgeo.org
    Wed Apr  9 08:29:58 PDT 2025
the project "PostGIS".
       via  5ae253cb6f7e598c735360688a5b36f35df8c239 (commit)
      from  f8187a32023d81aef97ddc3af0023c5d09c287eb (commit)
revisions in full, below.
commit 5ae253cb6f7e598c735360688a5b36f35df8c239
Author: amwps290 <huangning0722 at 163.com>
Date:   Wed Apr 9 15:58:54 2025 +0800
    fix PG_FREE_IF_COPY macro parameter position
diff --git a/postgis/lwgeom_export.c b/postgis/lwgeom_export.c
index e2d8731dc..cba082cea 100644
--- a/postgis/lwgeom_export.c
+++ b/postgis/lwgeom_export.c
@@ -394,7 +394,7 @@ Datum LWGEOM_asX3D(PG_FUNCTION_ARGS)
 	if (option & LW_X3D_USE_GEOCOORDS) {
 		if (lwgeom->srid != 4326)
-			PG_FREE_IF_COPY(geom, 0);
+			PG_FREE_IF_COPY(geom, 1);
 			/** TODO: we need to support UTM and other coordinate systems supported by X3D eventually
 			http://www.web3d.org/documents/specifications/19775-1/V3.2/Part01/components/geodata.html#t-earthgeoids **/
 			elog(ERROR, "Only SRID 4326 is supported for geocoordinates.");
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index d127d8dcd..9a16ad17f 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -3659,7 +3659,7 @@ Datum ST_ModEdgeSplit(PG_FUNCTION_ARGS)
   node_id = lwt_ModEdgeSplit(topo, edge_id, pt, 0);
   POSTGIS_DEBUG(1, "lwt_ModEdgeSplit returned");
   lwgeom_free(lwgeom);
-  PG_FREE_IF_COPY(geom, 3);
+  PG_FREE_IF_COPY(geom, 2);
   lwt_FreeTopology(topo);
   if ( node_id == -1 )
@@ -3729,7 +3729,7 @@ Datum ST_NewEdgesSplit(PG_FUNCTION_ARGS)
   node_id = lwt_NewEdgesSplit(topo, edge_id, pt, 0);
   POSTGIS_DEBUG(1, "lwt_NewEdgesSplit returned");
Summary of changes:
 postgis/lwgeom_export.c     | 2 +-
 topology/postgis_topology.c | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
