[PostGIS] #5862: TopoGeo_add* silently corrupt topology: edge crosses edge, mixed face labeling in ring
PostGIS trac at osgeo.org
Mon Apr 14 09:11:43 PDT 2025
labeling in ring
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  high               |  Milestone:
 Component:  topology           |    Version:  master
Resolution:                     |   Keywords:  robustness
Comment (by strk):
 I'm experimenting with using the GEOS 3.9 Precision overlay operations.
 Looks promising in that it would (at least in this case) avoid ending up
 with the initial state of having those internal vertices of edge2 so close
 to edge1 segment.
 Current master branch of PostGIS still only requires 3.8 so we'd have a
 mix of behaviors if we rely on that, but the advantages might out weight
 the disadvantages.
 WIP PR for that: https://git.osgeo.org/gitea/postgis/postgis/pulls/243
 Still we should probably run some checks to avoid creating invalid
 topologies as the biggest priority.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5862#comment:12>
