[SCM] PostGIS branch master updated. 3.5.0-266-g0acadb2c8
    git at osgeo.org
    git at osgeo.org
    Mon Apr 14 09:59:12 PDT 2025
the project "PostGIS".
       via  0acadb2c87fc07945aae2e68cc52e1ee38824e57 (commit)
      from  a21e080e6e8cc0e10a4ee278dea28e3267bc5af2 (commit)
revisions in full, below.
commit 0acadb2c87fc07945aae2e68cc52e1ee38824e57
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 14 18:58:59 2025 +0200
    Fix failure report
diff --git a/topology/test/regress/topogeo_addlinestring_robust.sql b/topology/test/regress/topogeo_addlinestring_robust.sql
index 0593771df..a5ca500be 100644
--- a/topology/test/regress/topogeo_addlinestring_robust.sql
+++ b/topology/test/regress/topogeo_addlinestring_robust.sql
@@ -139,8 +139,8 @@ BEGIN
       lbl,
       'area change',
       l,
-      rec.bfr::text,
-      rec.aft::text
+      bfr::text,
+      aft::text
     FROM (
       SELECT t.lbl l, ST_Area(t.g) bfr, ST_Area(tg::geometry) aft
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges.sql b/topology/test/regress/topogeo_addpoint_merge_edges.sql
index 65f996a15..7ad3e6bd9 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges.sql
+++ b/topology/test/regress/topogeo_addpoint_merge_edges.sql
@@ -132,8 +132,8 @@ BEGIN
       lbl,
       'area change',
       l,
-      rec.bfr::text,
-      rec.aft::text
+      bfr::text,
+      aft::text
     FROM (
Summary of changes:
 topology/test/regress/topogeo_addlinestring_robust.sql | 4 ++--
 topology/test/regress/topogeo_addpoint_merge_edges.sql | 4 ++--
 2 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
