[PostGIS] #5880: compile errors on PostGIS 3.1
trac at osgeo.org
Mon Apr 14 20:39:14 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.1.13
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by robe):
Nope for the debbie case, flipping to the same GEOS version as I could
have possibly built gdal with did not fix the issue.
23:35:11 -------------- Dependencies --------------
23:35:11 GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.11w64/bin/geos-config
23:35:11 GEOS version: 3.11.4
23:35:11 GDAL config:
/var/lib/jenkins/workspace/gdal/rel-3.10w64/bin/gdal-config
23:35:11 GDAL version: 3.10.3dev
23:35:11 SFCGAL config: /usr/bin/sfcgal-config
23:35:11 SFCGAL version: 1.3.8
23:35:11 PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg13w64/bin/pg_config
23:35:11 PostgreSQL version: PostgreSQL 13.20
23:35:11 PROJ4 version: 72
23:35:11 Libxml2 config: /usr/bin/xml2-config
23:35:11 Libxml2 version: 2.9.14
23:35:11 JSON-C support: yes
23:35:11 protobuf support: yes
23:35:11 protobuf-c version: 1003003
23:35:11 PCRE support: no
23:35:11 Perl: /usr/bin/perl
23:35:11 Wagyu: yes
23:36:44 gcc -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -fPIC
-DPIC -I../rt_core -I../../liblwgeom
-I/var/lib/jenkins/workspace/gdal/rel-3.10w64/include
-I/var/lib/jenkins/workspace/geos/rel-3.11w64/include -c raster2pgsql.c
23:36:45 /bin/bash ../../libtool --mode=link gcc -std=gnu99 -g -O2 -fno-
math-errno -fno-signed-zeros -fPIC -DPIC -I../rt_core -I../../liblwgeom
../rt_core/librtcore.a raster2pgsql.o -lm -static
../../liblwgeom/liblwgeom.la
-L/var/lib/jenkins/workspace/gdal/rel-3.10w64/lib -lgdal
-L/var/lib/jenkins/workspace/geos/rel-3.11w64/lib -lgeos_c -lc -o
raster2pgsql
23:36:45 libtool: link: gcc -std=gnu99 -g -O2 -fno-math-errno -fno-signed-
-I/var/lib/jenkins/workspace/geos/rel-3.11w64/include raster2pgsql.o -o
raster2pgsql ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.a -lm
-L/var/lib/jenkins/workspace/geos/rel-3.11w64/lib /usr/lib/x86_64-linux-
gnu/libproj.so -ljson-c -L/usr/lib/x86_64-linux-gnu -lSFCGAL -lgmpxx
-L/var/lib/jenkins/workspace/gdal/rel-3.10w64/lib -lgdal -lgeos_c -lc
23:36:45 /usr/bin/ld: ../../liblwgeom/.libs/liblwgeom.a(lwgeom_api.o): in
function `getPoint4d_p':
23:36:45
/var/lib/jenkins/workspace/postgis/branches/3.1/liblwgeom/lwgeom_api.c:139:
undefined reference to `lerror'
23:36:45 collect2: error: ld returned 1 exit status
23:36:45 make[2]: *** [Makefile:84: raster2pgsql] Error 1
23:36:45 make[2]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.1/raster/loader'
23:36:45 make[1]: *** [Makefile:35: rtloader] Error 2
23:36:45 make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.1/raster'
23:36:45 make: *** [GNUmakefile:22: all] Error 1
23:36:45 Build step 'Execute shell' marked build as failure
23:36:45 [Gitea] do not publish assets due to build being non-Successfully
23:36:45 Triggering a new build of PostgreSQL stop
23:36:45 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5880#comment:1>
