[PostGIS] #5862: TopoGeo_add* silently corrupt topology: edge crosses edge, mixed face labeling in ring
trac at osgeo.org
Tue Apr 15 02:30:48 PDT 2025
labeling in ring
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone:
Component: topology | Version: master
Resolution: | Keywords: robustness
Comment (by strk):
> Can this info be used to throw an topology exception ?
I've been thinking for a long time about exposing a function capable of
SPOTTING those occurrences. It's not very easy to do at the moment with
the PostGIS functions we have because what we are looking for is the
existance of distinct vertices that are closer than the topology tolerance
(easier) but also vertices that are closer than the topology tolerance
from SEGMENTS while not being *endpoints* of the segment.
The way such computation could be done NOW, with the functions we have,
would be to project each vertex against each segment within tolerance and
report if that projected point is NOT a vertex.
I guess I could work on such internal function but I wonder if any such
information would ALSO be useful to have exposed at the SQL level as a
standalone function. What would that be called, if we want to expose it ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5862#comment:15>
