[SCM] PostGIS branch stable-3.3 updated. 3.3.7-21-g86f6d9fbe
git at osgeo.org
git at osgeo.org
Tue Apr 15 07:49:35 PDT 2025
the project "PostGIS".
The branch, stable-3.3 has been updated
via 86f6d9fbe7b65e2c56360320e453a00e17a82349 (commit)
via e3f8415f2361cc5880569c260888ea1122f36afd (commit)
from 27328ea4022ea19f40743ddbebe002cd51f9abc3 (commit)
revisions in full, below.
commit 86f6d9fbe7b65e2c56360320e453a00e17a82349
Author: Regina Obe <lr at pcorp.us>
Date: Tue Apr 15 10:48:16 2025 -0400
WOODPECKER and doco changes
- force woodpecker only run on linux/amd64
- don't use deprecated woodpecker pipeline
- expand fiels to include for run to be yml changes
- Add note about postgis.backend being obsolete
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 0079f9a27..ef0016c4d 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,10 +1,16 @@
+labels:
+ platform: linux/amd64
+when:
+ event: [push, pull_request, tag]
steps:
- build:
- image: docker.osgeo.org/postgis/build-test:trisquel3
+ - name: build
+ image: repo.osgeo.org/postgis/build-test:trisquel3
when:
- event: push
- path: "doc/*"
+ path:
+ include: ['doc/*', '.woodpecker/*.yaml']
commands:
+ - export PATH=/usr/lib/postgresql/13/bin:$PATH
- ./autogen.sh
- mkdir -p build-docs && cd build-docs
- ../configure
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 15f7ef155..96c164378 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -1,3 +1,5 @@
+labels:
when:
variables:
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index e73ef478a..b052efb42 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -18,6 +18,7 @@ These can be set globally, by database, by session or by transaction. Best set a
<title>Description</title>
<para>This GUC is only relevant if you compiled PostGIS with sfcgal support. By default <varname>geos</varname> backend is used for functions where both GEOS and SFCGAL have the same named function. This variable allows you to override and make sfcgal the backend to service the request.</para>
<para>Availability: 2.1.0</para>
+ <warning><para>This switch does nothing as of PostGIS 3.0, DO NOT USE.</para></warning>
</refsection>
<refsection>
commit e3f8415f2361cc5880569c260888ea1122f36afd
Date: Fri Jan 17 22:20:26 2025 -0500
Update winnie versions
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 296712046..5e88528c8 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -11,11 +11,11 @@ export PROJECTS=/projects
export MSYS2_ARG_CONV_EXCL=/config/tags
if [[ "${OVERRIDE}" == '' ]] ; then
- export GEOS_VER=3.12.2
- export GDAL_VER=3.8.5
+ export GEOS_VER=3.13.0
+ export GDAL_VER=3.9.2
export PROJ_VER=8.2.1
- export SFCGAL_VER=1.5.1
- export CGAL_VER=5.6
+ export SFCGAL_VER=1.5.2
+ export CGAL_VER=5.6.1
export ICON_VER=1.17
export ZLIB_VER=1.2.13
export PROTOBUF_VER=3.2.0
@@ -28,7 +28,7 @@ fi;
export PROTOBUFC_VER=1.2.1
export JSON_VER=0.12
-export PCRE_VER=8.33
+export PCRE_VER=8.45
#export OS_BUILD=64
@@ -52,16 +52,16 @@ fi;
#set to something even if override is on but not set
if [[ "${LIBXML_VER}" == '' ]] ; then
- export LIBXML_VER=2.9.14
+ export LIBXML_VER=2.12.5
fi;
if [[ "${CGAL_VER}" == '' ]] ; then
fi;
##hard code versions of cgal etc. for now
-export CGAL_VER=5.6
+export CGAL_VER=5.6.1
BOOST_VER=1.84.0
export BOOST_VER_WU=1_84_0
Summary of changes:
.woodpecker/docs.yml | 12 +++++++++---
.woodpecker/regress.yml | 2 ++
ci/winnie/winnie_common.sh | 16 ++++++++--------
doc/reference_guc.xml | 1 +
4 files changed, 20 insertions(+), 11 deletions(-)
hooks/post-receive
