[PostGIS] #5881: CI failing on raster reprojection loader test
PostGIS trac at osgeo.org
Tue Apr 15 10:37:26 PDT 2025
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.3
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"614eca7c169cd6e9819801d3ea99d5258262c58b/git"
 614eca7c/git]:
 {{{#!CommitTicketReference repository="git"
 revision="614eca7c169cd6e9819801d3ea99d5258262c58b"
 Remove unnecessary raster-level check for a nodata value
 on the src, since the dst will always need a nodata value
 in order to infill the gaps created by the raster warping
 process. In general at least, and doing it in specific
 (only for warps that create empty cells) would be way too
 complex.
 References #5881
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5881#comment:2>
