[SCM] PostGIS branch master updated. 3.5.0-272-gc06333052
git at osgeo.org
git at osgeo.org
Tue Apr 15 11:52:47 PDT 2025
the project "PostGIS".
via c06333052c9be44691ab20b1e8523921e02d8870 (commit)
from 6144d2ad57f2d5b436eff83a1c58e3f2e1963b91 (commit)
revisions in full, below.
commit c06333052c9be44691ab20b1e8523921e02d8870
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Apr 15 11:46:12 2025 -0700
Update POSTGIS_GDAL_VERSION to use Mmmpp format
diff --git a/configure.ac b/configure.ac
index ccb778064..45022c713 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1587,7 +1587,8 @@ if test "x$with_raster" != "xno"; then
dnl GDAL version constants, update here
GDAL_MIN_VERSION=2.0.0
- GDAL_MIN_VERSION_NUMBER=180 dnl TODO: Use GDAL version calculation MAJOR*1000+MINOR*100+REV*10+BUILD
+ dnl Compare to POSTGIS_GDAL_VERSION
+ GDAL_MIN_VERSION_NUMBER=20000
AC_ARG_WITH(
[gdalconfig],
@@ -1613,13 +1614,12 @@ if test "x$with_raster" != "xno"; then
GDAL_MINOR_VERSION=`$GDAL_CONFIG --version | cut -d. -f2 | sed 's/[[^0-9]]//g'`
GDAL_PATCH_VERSION=`$GDAL_CONFIG --version | cut -d. -f3 | sed 's/[[^0-9]]//g'`
GDAL_FULL_VERSION=`$GDAL_CONFIG --version`
- POSTGIS_GDAL_VERSION="$GDAL_MAJOR_VERSION$GDAL_MINOR_VERSION"
- GDAL_VERSION_NUMBER="$GDAL_MAJOR_VERSION$GDAL_MINOR_VERSION$GDAL_PATCH_VERSION"
+ POSTGIS_GDAL_VERSION=`echo $GDAL_FULL_VERSION | $PERL -nle 'printf "%d%02d%02d\n",$1,$2,$3 if /(\d+)\.(\d+)\.(\d+)/'`
AC_MSG_RESULT([$GDAL_FULL_VERSION])
dnl Ensure we are using minimum required version of GDAL
- if test ! "$GDAL_VERSION_NUMBER" -ge "$GDAL_MIN_VERSION_NUMBER" ; then
+ if test ! "$POSTGIS_GDAL_VERSION" -ge "$GDAL_MIN_VERSION_NUMBER" ; then
AC_MSG_ERROR([PostGIS raster requires GDAL >= $GDAL_MIN_VERSION. Use --without-raster to build without raster support.])
fi
diff --git a/raster/rt_core/rt_gdal.c b/raster/rt_core/rt_gdal.c
index 6303c5ee9..748a8ff12 100644
--- a/raster/rt_core/rt_gdal.c
+++ b/raster/rt_core/rt_gdal.c
@@ -157,7 +157,7 @@ int rt_raster_gdal_contour(
return _rti_contour_arg_destroy(&arg);
/* Polygonize is 2.4+ only */
-#if POSTGIS_GDAL_VERSION >= 24
+#if POSTGIS_GDAL_VERSION >= 20400
arg.dst.gtype = polygonize ? wkbPolygon : wkbLineString;
#else
arg.dst.gtype = wkbLineString;
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index ca055cf6c..55ccee6f9 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -2825,7 +2825,7 @@ rt_raster_gdal_rasterize(
_dim[1] == 0
-#if POSTGIS_GDAL_VERSION > 18
+#if POSTGIS_GDAL_VERSION > 10800
RASTER_DEBUG(3, "Adjusting extent for GDAL > 1.8 by half the scale on X-axis");
extent.MinX -= (_scale[0] / 2.);
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index fadaa9611..228717f36 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -269,7 +269,7 @@ rt_pg_options(const char* varname)
static stringlist_t *vsi_option_stringlist = NULL;
-#if POSTGIS_GDAL_VERSION < 23
+#if POSTGIS_GDAL_VERSION < 20300
* For older versions of GDAL we have extracted the list of options
@@ -341,7 +341,7 @@ rt_pg_vsi_load_all_options(void)
stringlist_sort(vsi_option_stringlist);
-#else /* POSTGIS_GDAL_VERSION < 23 */
+#else /* POSTGIS_GDAL_VERSION < 20300 */
* For newer versions of GDAL the VSIGetFileSystemOptions() call returns
@@ -413,7 +413,7 @@ rt_pg_vsi_load_all_options(void)
-#endif /* POSTGIS_GDAL_VERSION < 23 */
+#endif /* POSTGIS_GDAL_VERSION < 20300 */
static bool
Summary of changes:
configure.ac | 8 ++++----
raster/rt_core/rt_gdal.c | 2 +-
raster/rt_core/rt_raster.c | 2 +-
raster/rt_pg/rtpostgis.c | 6 +++---
4 files changed, 9 insertions(+), 9 deletions(-)
hooks/post-receive
