[SCM] PostGIS branch master updated. 3.5.0-275-g8e6d57242
git at osgeo.org
git at osgeo.org
Tue Apr 15 12:31:44 PDT 2025
the project "PostGIS".
via 8e6d57242844ddc68fce01f3bcb038482afff69a (commit)
from b5385d5bf4050bc927ba1c29fd893c3045e15dd8 (commit)
revisions in full, below.
commit 8e6d57242844ddc68fce01f3bcb038482afff69a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Apr 15 12:31:40 2025 -0700
Remove doc entry for postgis_backend GUC, which is long gone
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index d95a91d73..6e423ebbf 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -8,31 +8,6 @@ These can be set globally, by database, by session or by transaction. Best set a
and <link xlink:href="https://www.postgresql.org/docs/current/sql-altersystem.html">SQL ALTER SYSTEM</link></para>
</abstract>
</info>
- <refentry xml:id="postgis_backend">
- <refnamediv>
- <refname>postgis.backend</refname>
- <refpurpose>The backend to service a function where GEOS and SFCGAL overlap. Options: geos or sfcgal. Defaults to geos.</refpurpose>
- </refnamediv>
- <refsection>
- <title>Description</title>
- <para>This GUC is only relevant if you compiled PostGIS with sfcgal support. By default <varname>geos</varname> backend is used for functions where both GEOS and SFCGAL have the same named function. This variable allows you to override and make sfcgal the backend to service the request.</para>
- <para role="availability" conformance="2.1.0">Availability: 2.1.0</para>
- </refsection>
- <refsection>
- <title>Examples</title>
- <para>Sets backend just for life of connection</para>
- <programlisting>set postgis.backend = sfcgal;</programlisting>
- <para>Sets backend for new connections to database</para>
- <programlisting>ALTER DATABASE mygisdb SET postgis.backend = sfcgal;</programlisting>
- </refsection>
- <refsection>
- <title>See Also</title>
- <para><xref linkend="reference_sfcgal"/></para>
- </refsection>
- </refentry>
<refentry xml:id="postgis_gdal_datapath">
<refnamediv>
Summary of changes:
doc/reference_guc.xml | 25 -------------------------
1 file changed, 25 deletions(-)
hooks/post-receive
