[PostGIS] #5882: ST_DistanceCPA example shows output of 2D distance. Implementation returns 3D distance.
trac at osgeo.org
Mon Apr 21 14:47:37 PDT 2025
3D distance.
Reporter: siggyf | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: documentation | Version: 3.4.x
Keywords: CPA |
There is an example that computes the closest point of approach between
two trajectories. The example is listed at [1] and involves calling the
function:
`ST_DistanceCPA(a,b)`
The example states that the result is `1.96036833151395`.
The actual result that I get is `1.965214737762069`.
I get the actual result by pasting the example code listed at the line
below [2] into postgis 3.5.2 with postgresql 16.8. I have also
reimplemented the same routine in python. There I get `1.965214737762069`
for 3D distances and `1.96036833151395` for 2D using the example
trajectories.
There are two other places where the same function is called [3] and [4].
The three examples that I found are the following:
- [1] -> `1.96036833151395` `ST_DistanceCPA`, I think this is incorrect,
because I expect the 3D distance. Documentation states "This function
supports 3d and will not drop the z-index."
- [3] -> `1.965214737762069` `ST_DistanceCPA`, Here the correct 3D result
is shown.
- [4] -> `1.9603683315139542` `ST_Distance`, Here the points are found
using interpolation of time. Here the 2D distance function is called, so
1.960 is expected. For consistency with [3] ST_Distance could be replaced
with ST_3DDistance, which would give 1.965.
Because the CPA concept is also used in 3D (underwater uav's, distance
between planes) returning 3D distance seems intuitive.
Code of the corresponding algorithm is found in lwgeom [5].
- [1] https://postgis.net/docs/ST_DistanceCPA.html
- [2]
https://github.com/postgis/postgis/blob/d8c2e69f33458eaf3200e850f58a6d8f7cc0c554/doc/reference_trajectory.xml#L195
- [3] https://postgis.net/docs/ST_CPAWithin.html
- [4] https://postgis.net/docs/ST_ClosestPointOfApproach.html
- [5]
https://github.com/postgis/postgis/blob/master/liblwgeom/lwlinearreferencing.c#L1138
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5882>
