[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
PostGIS trac at osgeo.org
Tue Apr 22 09:35:35 PDT 2025
  Reporter:  nbvfgh    |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  postgis   |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by pramsey):
 I come at this with two impulses:
 * One is just to remove the constraint-reading bits of the view, since
 they date back to pre-2.0 postgis, when we didn't have typmods.
 * The other is to replace the string manipulation stuff with a single
 regex.
 # select pg_get_constraintdef(177252);
  CHECK (((st_srid(geom) = 4326) AND st_isvalid(geom)))
 # select regexp_match(
            pg_get_constraintdef(177252),
            'st_srid\(\w+\)\s*=\s*(\d+)', 'i');
  regexp_match
  {4326}
 That would be more reliable than the current code and leave in place the
 constraint support, for those 15 year old legacy systems we care about.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829#comment:1>
