[PostGIS] #5829: SELECT geometry_columns returns unexpected error when there are constraints after SRID constraint.
PostGIS trac at osgeo.org
Tue Apr 22 11:24:38 PDT 2025
  Reporter:  nbvfgh    |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  postgis   |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"a6b036da73c80421f19d3e25c5b983a3a989e18c/git"
 a6b036da/git]:
 {{{#!CommitTicketReference repository="git"
 revision="a6b036da73c80421f19d3e25c5b983a3a989e18c"
 geometry_columns view fails with non-standard use of postgis functions in
 constraint definition, references #5829
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5829#comment:5>
