[SCM] PostGIS branch stable-3.3 updated. 3.3.7-24-g31840ab56
git at osgeo.org
git at osgeo.org
Tue Apr 22 12:50:44 PDT 2025
the project "PostGIS".
The branch, stable-3.3 has been updated
via 31840ab5610c21113f5ae9eb4dd7738b7c4fe1a2 (commit)
from 102b938f4425d3722546bf5b14b51360b43a2615 (commit)
revisions in full, below.
commit 31840ab5610c21113f5ae9eb4dd7738b7c4fe1a2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Apr 22 12:50:36 2025 -0700
Use standard conforming strings
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2bebee475..c8629354a 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6306,28 +6306,28 @@ CREATE OR REPLACE VIEW geometry_columns AS
LEFT JOIN ( SELECT s.connamespace,
s.conrelid,
s.conkey,
- (regexp_match(s.consrc, 'geometrytype\(\w+\)\s*=\s*(\w+)', 'i'))[1]::text AS type
+ (regexp_match(s.consrc, E'geometrytype\(\w+\)\s*=\s*(\w+)', E'i'))[1]::text AS type
FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
FROM pg_constraint) AS s
- WHERE s.consrc ~* 'geometrytype(\w+)\s*=\s*\w+'::text
+ WHERE s.consrc ~* E'geometrytype(\w+)\s*=\s*\w+'::text
) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
s.conrelid,
s.conkey,
- (regexp_match(s.consrc, 'ndims\(\w+\)\s*=\s*(\d+)', 'i'))[1]::integer AS ndims
+ (regexp_match(s.consrc, E'ndims\(\w+\)\s*=\s*(\d+)', E'i'))[1]::integer AS ndims
- WHERE s.consrc ~* 'ndims(\w+)\s*=\s*\d+'::text
+ WHERE s.consrc ~* E'ndims(\w+)\s*=\s*\d+'::text
) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
s.conrelid,
s.conkey,
- (regexp_match(s.consrc, 'st_srid\(\w+\)\s*=\s*(\d+)', 'i'))[1]::integer As srid
+ (regexp_match(s.consrc, E'srid\(\w+\)\s*=\s*(\d+)', E'i'))[1]::integer As srid
- WHERE s.consrc ~* 'srid(\w+)\s*=\s*\d+'::text
+ WHERE s.consrc ~* E'srid(\w+)\s*=\s*\d+'::text
) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
Summary of changes:
postgis/postgis.sql.in | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
