[SCM] PostGIS branch stable-3.5 updated. 3.5.2-30-gcf9783c57
git at osgeo.org
git at osgeo.org
Tue Apr 22 15:01:43 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via cf9783c57ca376cc7246c1c4b1c56e89cec59d8f (commit)
from 07f2a23a5fb8d0a361e5a4b2079c3c13d6a672d7 (commit)
revisions in full, below.
commit cf9783c57ca376cc7246c1c4b1c56e89cec59d8f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Apr 22 15:01:31 2025 -0700
Harmonize docs with results for ST_DistanceCPA, references #5882
diff --git a/doc/reference_trajectory.xml b/doc/reference_trajectory.xml
index e5464d9f6..8cc186189 100644
--- a/doc/reference_trajectory.xml
+++ b/doc/reference_trajectory.xml
@@ -2,50 +2,50 @@
<section xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Temporal">
<title>Trajectory Functions</title><info>
<abstract>
- <para>These functions support working with trajectories.
- A trajectory is a linear geometry with increasing measures (M value) on each coordinate.
- Spatio-temporal data can be modeled by using relative times (such as the epoch)
- as the measure values.
- </para>
+ <para>These functions support working with trajectories.
+ A trajectory is a linear geometry with increasing measures (M value) on each coordinate.
+ Spatio-temporal data can be modeled by using relative times (such as the epoch)
+ as the measure values.
+ </para>
</abstract>
</info>
- <refentry xml:id="ST_IsValidTrajectory">
- <refnamediv>
- <refname>ST_IsValidTrajectory</refname>
- <refpurpose>Tests if the geometry is a valid trajectory.</refpurpose>
- </refnamediv>
+ <refentry xml:id="ST_IsValidTrajectory">
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>boolean <function>ST_IsValidTrajectory</function></funcdef>
- <paramdef><type>geometry </type> <parameter>line</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
+ <refnamediv>
+ <refname>ST_IsValidTrajectory</refname>
+ <refpurpose>Tests if the geometry is a valid trajectory.</refpurpose>
+ </refnamediv>
- <refsection>
- <title>Description</title>
- <para>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>boolean <function>ST_IsValidTrajectory</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>line</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>
Tests if a geometry encodes a valid trajectory.
A valid trajectory is represented as a <varname>LINESTRING</varname>
with measures (M values).
The measure values must increase from each vertex to the next.
- </para>
- <para>
+ </para>
+ <para>
Valid trajectories are expected as input to spatio-temporal functions
like <xref linkend="ST_ClosestPointOfApproach"/>
- </para>
- <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
- <para>&Z_support;</para>
- </refsection>
+ </para>
+ <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
+ <para>&Z_support;</para>
+ </refsection>
- <refsection>
- <title>Examples</title>
+ <refsection>
+ <title>Examples</title>
<programlisting>
-- A valid trajectory
SELECT ST_IsValidTrajectory(ST_MakeLine(
@@ -61,58 +61,58 @@ NOTICE: Measure of vertex 1 (0) not bigger than measure of vertex 0 (1)
f
</programlisting>
- </refsection>
+ </refsection>
- <refsection>
- <title>See Also</title>
- <para>
+ <refsection>
+ <title>See Also</title>
+ <para>
- </para>
- </refsection>
- </refentry>
+ </para>
+ </refsection>
+ </refentry>
- <refentry xml:id="ST_ClosestPointOfApproach">
+ <refentry xml:id="ST_ClosestPointOfApproach">
- <refnamediv>
- <refname>ST_ClosestPointOfApproach</refname>
- <refpurpose>
+ <refnamediv>
+ <refname>ST_ClosestPointOfApproach</refname>
+ <refpurpose>
Returns a measure at the closest point of approach of two trajectories.
</refpurpose>
- </refnamediv>
+ </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>float8 <function>ST_ClosestPointOfApproach</function></funcdef>
- <paramdef><type>geometry </type> <parameter>track1</parameter></paramdef>
- <paramdef><type>geometry </type> <parameter>track2</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float8 <function>ST_ClosestPointOfApproach</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>track1</parameter></paramdef>
+ <paramdef><type>geometry </type> <parameter>track2</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
- <refsection>
+ <refsection>
- <para>
+ <para>
Returns the smallest measure at which points interpolated along the given
trajectories are the least distance apart.
</para>
- <para>
+ <para>
Inputs must be valid trajectories as
checked by <xref linkend="ST_IsValidTrajectory"/>. Null is returned if
the trajectories do not overlap in their M ranges.
- </para>
+ </para>
- <para>
+ <para>
To obtain the actual points at the computed measure use <xref linkend="ST_LocateAlong"/> .
- </para>
+ </para>
- </refsection>
+ </refsection>
- <refsection>
+ <refsection>
<programlisting>
-- Return the time in which two objects moving between 10:00 and 11:00
-- are closest to each other and their distance at that point
@@ -133,65 +133,65 @@ WITH inp AS ( SELECT
FROM inp, cpa
SELECT to_timestamp(m) t,
- ST_Distance(pa,pb) distance,
+ ST_3DDistance(pa,pb) distance,
ST_AsText(pa, 2) AS pa, ST_AsText(pb, 2) AS pb
FROM points, cpa;
t | distance | pa | pb
- 2015-05-26 10:45:31.034483-07 | 1.9603683315139542 | POINT ZM (7.59 0 3.79 1432662331.03) | POINT ZM (9.1 1.24 3.93 1432662331.03)
+ 2015-05-26 10:45:31.034483-07 | 1.9652147377620688 | POINT ZM (7.59 0 3.79 1432662331.03) | POINT ZM (9.1 1.24 3.93 1432662331.03)
</programlisting>
- </refsection>
+ </refsection>
- <refsection>
- <para>
+ <refsection>
+ <para>
<xref linkend="ST_IsValidTrajectory"/>,
<xref linkend="ST_DistanceCPA"/>,
<xref linkend="ST_LocateAlong"/>,
<xref linkend="ST_AddMeasure"/>
- </para>
- </refsection>
- </refentry>
+ </para>
+ </refsection>
+ </refentry>
- <refentry xml:id="ST_DistanceCPA">
+ <refentry xml:id="ST_DistanceCPA">
- <refnamediv>
- <refname>ST_DistanceCPA</refname>
- <refpurpose>
+ <refnamediv>
+ <refname>ST_DistanceCPA</refname>
+ <refpurpose>
Returns the distance between the closest point of approach of two trajectories.
</refpurpose>
- </refnamediv>
+ </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>float8 <function>ST_DistanceCPA</function></funcdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>float8 <function>ST_DistanceCPA</function></funcdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
- <refsection>
+ <refsection>
- <para>
+ <para>
Returns the distance (in 2D) between two trajectories at their closest point of approach.
</para>
- <para>
+ <para>
Inputs must be valid trajectories as checked by
Null is returned if the trajectories do not overlap in their M ranges.
- </para>
+ </para>
- </refsection>
+ </refsection>
- <refsection>
+ <refsection>
<programlisting>
-- Return the minimum distance of two objects moving between 10:00 and 11:00
@@ -207,62 +207,62 @@ WITH inp AS ( SELECT
SELECT ST_DistanceCPA(a,b) distance FROM inp;
distance
- 1.96036833151395
+ 1.965214737762069
</programlisting>
- </refsection>
+ </refsection>
- <refsection>
- <para>
+ <refsection>
+ <para>
<xref linkend="ST_ClosestPointOfApproach"/>,
<xref linkend="ST_AddMeasure"/>,
<xref linkend="geometry_distance_cpa"/>
- </para>
- </refsection>
- </refentry>
+ </para>
+ </refsection>
+ </refentry>
- <refentry xml:id="ST_CPAWithin">
+ <refentry xml:id="ST_CPAWithin">
- <refnamediv>
- <refname>ST_CPAWithin</refname>
- <refpurpose>
+ <refnamediv>
+ <refname>ST_CPAWithin</refname>
+ <refpurpose>
Tests if the closest point of approach of two trajectories
is within the specified distance.
</refpurpose>
- </refnamediv>
+ </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>boolean <function>ST_CPAWithin</function></funcdef>
- <paramdef><type>float8 </type> <parameter>dist</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>boolean <function>ST_CPAWithin</function></funcdef>
+ <paramdef><type>float8 </type> <parameter>dist</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
- <refsection>
+ <refsection>
- <para>
+ <para>
Tests whether two moving objects have ever been closer than the specified distance.
</para>
- <para>
+ <para>
False is returned if the trajectories do not overlap in their M ranges.
- </para>
+ </para>
- </refsection>
+ </refsection>
- <refsection>
+ <refsection>
<programlisting>
ST_AddMeasure('LINESTRING Z (0 0 0, 10 0 5)'::geometry,
@@ -280,18 +280,18 @@ SELECT ST_CPAWithin(a,b,2), ST_DistanceCPA(a,b) distance FROM inp;
t | 1.96521473776207
</programlisting>
- </refsection>
+ </refsection>
- <!-- Optionally add a "See Also" section -->
- <refsection>
- <para>
+ <!-- Optionally add a "See Also" section -->
+ <refsection>
+ <para>
- </para>
- </refsection>
- </refentry>
+ </para>
+ </refsection>
+ </refentry>
- </section>
\ No newline at end of file
+ </section>
Summary of changes:
doc/reference_trajectory.xml | 304 +++++++++++++++++++++----------------------
1 file changed, 152 insertions(+), 152 deletions(-)
hooks/post-receive
