[SCM] PostGIS branch stable-3.4 updated. 3.4.4-15-g6bc589417
git at osgeo.org
git at osgeo.org
Tue Apr 22 17:57:35 PDT 2025
the project "PostGIS".
The branch, stable-3.4 has been updated
via 6bc589417188b4480d8f84108a5514c923d6c131 (commit)
from d6da6d2385d258c92bb5667612ef53fd7ca12290 (commit)
revisions in full, below.
commit 6bc589417188b4480d8f84108a5514c923d6c131
Author: Regina Obe <lr at pcorp.us>
Date: Tue Apr 22 20:56:48 2025 -0400
WOODPECKER CHANGES
- use repo.osgeo.org instead of docker.osgeo.org
- use environment mappings (other way is deprecated)
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 00e085186..ad5fa038a 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,5 +1,5 @@
variables:
- - &test_image 'docker.osgeo.org/postgis/build-test:trisquel3'
+ - &test_image 'repo.osgeo.org/postgis/build-test:trisquel3'
- common_doc_paths: &common_doc_paths
# related config files
- ".woodpecker/docs.yml"
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 0a52492bc..e6bf5ad09 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -1,7 +1,7 @@
when:
event: [push, pull_request, tag]
variables:
- test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel3
+ test-image: &test-image repo.osgeo.org/postgis/build-test:trisquel3
steps-env: &steps-env
- export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
- export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
@@ -57,7 +57,7 @@ steps:
image: *test-image
depends_on: autogen
environment:
- - PGVER=12
+ PGVER: 12
commands:
- <<: *steps-env
- <<: *steps-pg-build
@@ -66,7 +66,7 @@ steps:
image: *test-image
depends_on: autogen
environment:
- - PGVER=15
+ PGVER: 15
commands:
- <<: *steps-env
@@ -75,7 +75,7 @@ steps:
image: *test-image
depends_on: build-pg12
environment:
- - PGVER=12
+ PGVER: 12
commands:
- <<: *steps-env
- <<: *steps-start-postgresql
@@ -85,7 +85,7 @@ steps:
image: *test-image
depends_on: build-pg15
environment:
- - PGVER=15
+ PGVER: 15
commands:
- <<: *steps-env
@@ -95,7 +95,7 @@ steps:
image: *test-image
environment:
- - PGVER=12
+ PGVER: 12
commands:
- <<: *steps-env
@@ -106,7 +106,7 @@ steps:
image: *test-image
environment:
- - PGVER=15
+ PGVER: 15
commands:
- <<: *steps-env
@@ -117,7 +117,7 @@ steps:
image: *test-image
environment:
- - PGVER=12
+ PGVER: 12
commands:
- <<: *steps-env
@@ -128,7 +128,7 @@ steps:
image: *test-image
environment:
- - PGVER=15
+ PGVER: 15
commands:
- <<: *steps-env
diff --git a/.woodpecker/tools.yml b/.woodpecker/tools.yml
index 0d5033f07..9824a0fc7 100644
--- a/.woodpecker/tools.yml
+++ b/.woodpecker/tools.yml
@@ -2,7 +2,7 @@ when:
steps:
build:
- image: docker.osgeo.org/postgis/build-test:trisquel3
+ image: repo.osgeo.org/postgis/build-test:trisquel3
pull: true
commands:
- sh ci/dronie/postgis_tools.sh
Summary of changes:
.woodpecker/docs.yml | 2 +-
.woodpecker/regress.yml | 18 +++++++++---------
.woodpecker/tools.yml | 2 +-
3 files changed, 11 insertions(+), 11 deletions(-)
hooks/post-receive
