[PostGIS] #5872: CG_StraightSkeletonPartition should return a geometry collection instead of a multipolygon
trac at osgeo.org
Wed Apr 23 07:07:38 PDT 2025
a multipolygon
Reporter: robe | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: sfcgal | Version: master
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:1 Loïc Bartoletti]:
> You're right, a MultiPolygon will always invalid.
> I think that I used
[https://gitlab.com/sfcgal/SFCGAL/-/blob/master/src/algorithm/straightSkeleton.cpp?ref_type=heads#L492
MultiPolygon] type because it was simpler (and what we have done for
subdivde in QGIS).
> But it's true that we have an SRF in PostGIS. In fact, we can also
return a SRF for CG_StraightSkeleton. However, in the case of SFCGAL, I
think it's probably more appropriate to do a PolyhedralSurface (moreover
PolyhedralSurface and TIN are well-supported in QGIS now). What do you
think?
Agree that polyhedral surface makes most sense. And given you can reduce
that to polygons using ST_Dump I think that should be fine. We can always
add a doc example showing using ST_Dump to explode into polygons for those
that can't operated with polyhedral surfaces.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5872#comment:3>
