[PostGIS] #4793: ST_IsSolid returns false after using ST_MakeSolid with a closed polyhedral surface
    trac at osgeo.org
    Thu Apr 24 21:52:56 PDT 2025
surface
  Reporter:  basilrabi  |      Owner:  colivier
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS SFCGAL
 Component:  sfcgal     |    Version:  3.0.x
Resolution:  fixed      |   Keywords:
Changes (by Loïc Bartoletti):
 * resolution:   => fixed
 * status:  new => closed
Old description:
> # POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="130" GEOS="3.7.1-CAPI-1.11.1
> 27a5e771" SFCGAL="1.3.6" PROJ="Rel. 5.2.0, September 15th, 2018"
> GDAL="GDAL 2.4.0, released 2018/12/14" LIBXML="2.9.4" LIBJSON="0.12.1"
> LIBPROTOBUF="1.3.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
> WITH cte AS (
>     SELECT ST_MakeSolid(
>         ST_Extrude(
>             ST_Translate(
>                 ST_Force3D(
>                     ST_GeomFromText('POLYGON ((-1 1,1 1,1 -1,-1 -1,-1
> 1))')
>                 0, 0, -1
>             0, 0, 2
>     ) geom
> SELECT
>     ST_IsSolid(geom),
>     ST_IsClosed(geom),
>     ST_Volume(geom)
> FROM cte
> The code above returns false, true, 8. I could be wrong but based on my
> understanding in the manual, this should return true, true, 8.
New description:
 WITH cte AS (
         ST_Extrude(
             ST_Translate(
                 ST_Force3D(
 1))')
                 0, 0, -1
             0, 0, 2
     ) geom
 SELECT
     ST_IsSolid(geom),
     ST_IsClosed(geom),
     ST_Volume(geom)
 FROM cte
Comment:
 Fixed, cf ticket:5818
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4793#comment:1>
