[SCM] PostGIS branch master updated. 3.5.0-290-g0d16b359f
Mon Apr 28 02:48:01 PDT 2025
the project "PostGIS".
       via  0d16b359f9049379cd69dbfb1a6c0271d1d19cf3 (commit)
      from  f22e2506a02fa17cefece2c6d6399042c3d54946 (commit)
revisions in full, below.
commit 0d16b359f9049379cd69dbfb1a6c0271d1d19cf3
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Mon Apr 28 09:44:14 2025 +0200
    tests(Partition): Fix tests and results
    Fix against https://trac.osgeo.org/postgis/ticket/5872
diff --git a/NEWS b/NEWS
index 78d68a953..082c60ce9 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ PostGIS 3.6.0
 * Bug fixes *
   - #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
+  - #5872, GH-796 Fix tests and results for SK Partition (Loïc Bartoletti)
 * Breaking Changes *
diff --git a/sfcgal/regress/sfcgal_v2.sql b/sfcgal/regress/sfcgal_v2.sql
index 06c01ed1f..aedb60a49 100644
--- a/sfcgal/regress/sfcgal_v2.sql
+++ b/sfcgal/regress/sfcgal_v2.sql
@@ -10,7 +10,7 @@ SELECT 'CG_3DScale', ST_AsText(CG_3DScale('POINT(1 1 1)', 2, 3, 4), 0);
 SELECT 'CG_3DScaleAroundCenter', ST_AsText(ST_ReducePrecision(CG_3DScaleAroundCenter('POINT(2 2 2)', 0.5, 0.5, 0.5, 1, 1, 1), 0.1));
 SELECT 'CG_Translate', ST_AsText(CG_Translate('LINESTRING(1 1, 2 2)', 1, -1), 0);
 SELECT 'CG_3DTranslate', ST_AsText(CG_3DTranslate('POINT(1 1 1)', 1, -1, 2), 0);
-SELECT 'CG_StraightSkeletonPartition', ST_AsText(CG_StraightSkeletonPartition('POLYGON((0 0, 4 0, 2 2, 0 0))', true), 2);
+SELECT 'CG_StraightSkeletonPartition', ST_AsText(ST_Collect(dmp.geom), 2) FROM ST_Dump(CG_StraightSkeletonPartition('POLYGON((0 0, 4 0, 2 2, 0 0))', true)) as dmp;
 SELECT 'CG_3DBuffer', ST_AsText(CG_3DBuffer('POINT(0 0 0)', 1, 8, 0), 2);
 SELECT 'CG_Rotate', ST_AsText(ST_ReducePrecision(CG_Rotate('LINESTRING  EMPTY', pi()/2), 0.1));
 SELECT 'CG_2DRotate', ST_AsText(CG_2DRotate('POINT EMPTY', pi()/2, 1, 1), 0);
@@ -23,5 +23,5 @@ SELECT 'CG_3DScale', ST_AsText(CG_3DScale('POINT EMPTY', 2, 3, 4), 0);
 SELECT 'CG_3DScaleAroundCenter', ST_AsText(ST_ReducePrecision(CG_3DScaleAroundCenter('POINT EMPTY', 0.5, 0.5, 0.5, 1, 1, 1), 0.1));
 SELECT 'CG_Translate', ST_AsText(CG_Translate('LINESTRING EMPTY', 1, -1), 0);
 SELECT 'CG_3DTranslate', ST_AsText(CG_3DTranslate('POINT EMPTY', 1, -1, 2), 0);
-SELECT 'CG_StraightSkeletonPartition', ST_AsText(CG_StraightSkeletonPartition('POLYGON EMPTY', true), 2);
+SELECT 'CG_StraightSkeletonPartition', replace(ST_AsText(CG_StraightSkeletonPartition('POLYGON EMPTY', true), 2), 'MULTIPOLYGON', 'POLYHEDRALSURFACE');
 SELECT 'CG_3DBuffer', ST_AsText(CG_3DBuffer('POINT EMPTY', 1, 8, 0), 2);
diff --git a/sfcgal/regress/sfcgal_v2_expected b/sfcgal/regress/sfcgal_v2_expected
index 77eebaf30..4560a0926 100644
--- a/sfcgal/regress/sfcgal_v2_expected
+++ b/sfcgal/regress/sfcgal_v2_expected
@@ -22,5 +22,5 @@ CG_3DScale|POINT Z EMPTY
 CG_3DScaleAroundCenter|POINT Z EMPTY
 CG_Translate|LINESTRING EMPTY
 CG_3DTranslate|POINT Z EMPTY
-CG_StraightSkeletonPartition|MULTIPOLYGON EMPTY
+CG_StraightSkeletonPartition|POLYHEDRALSURFACE EMPTY
 CG_3DBuffer|POLYHEDRALSURFACE EMPTY
Summary of changes:
 NEWS                              | 1 +
 sfcgal/regress/sfcgal_v2.sql      | 4 ++--
 sfcgal/regress/sfcgal_v2_expected | 2 +-
 3 files changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
