[SCM] PostGIS branch stable-3.1 updated. 3.1.11-23-g26a4636ea
git at osgeo.org
git at osgeo.org
Mon Apr 28 03:33:37 PDT 2025
the project "PostGIS".
The branch, stable-3.1 has been updated
via 26a4636eae914a855b4dfaaa9df35b7863765895 (commit)
from 36115b41a44744516afe48fae158276fc596ce97 (commit)
revisions in full, below.
commit 26a4636eae914a855b4dfaaa9df35b7863765895
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Apr 28 11:09:17 2025 +0200
Reword paragraph about gridSize parameter of overlay operations
The text erroneously reported that the input geometries would
be snapped to the given grid, while instead it is EXPECTED to
be already snapped.
This change turns the corrisponding documentation snippet into
a reusable tag and uses it in all appropriate overlay operation
sections.
Closes #5885 in 3.1 branch (3.1.13dev)
diff --git a/doc/postgis.xml b/doc/postgis.xml
index e67559dae..9a0a48139 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -71,6 +71,13 @@
url='http://www.opengeospatial.org/standards/sfs'>OpenGIS Simple Features
Implementation Specification for SQL 1.1.</ulink>">
+<!ENTITY overlay_gridsize_arg
+"If the optional <code>gridSize</code> parameter is given (GEOS-3.9.0 or higher required),
+all result vertices are guaranteed to fall on a grid of the specified
+size. For the operation to give predictable results all the input vertices
+must fall already on the specified grid, see <xref linkend='ST_ReducePrecision'/>.
<!ENTITY sqlmm_compliant
"<inlinemediaobject>
<imageobject>
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 19c7fda9b..32d2070d9 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -90,11 +90,7 @@ SELECT ST_ClipByBox2D(the_geom, ST_MakeEnvelope(0,0,10,10)) FROM mytab;
<note><para>This is the only overlay function where input order matters.
ST_Difference(A, B) always returns a portion of A.</para></note>
- <para>
-If the optional <code>gridSize</code> argument is provided, the inputs are
-snapped to a grid of the given size, and the result vertices are computed
-on that same grid. (Requires GEOS-3.9.0 or higher)
- </para>
+ <para> &overlay_gridsize_arg; </para>
<para>Performed by the GEOS module</para>
<para>Enhanced: 3.1.0 accept a gridSize parameter - requires GEOS >= 3.9.0</para>
@@ -167,7 +163,12 @@ MULTIPOINT(-118.6 38.329 6,-118.58 38.38 5)
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_SymDifference" />, <xref linkend="ST_Intersection" />, <xref linkend="ST_Union" /></para>
+ <para>
+<xref linkend="ST_SymDifference"/>,
+<xref linkend="ST_Intersection"/>,
+<xref linkend="ST_Union"/>,
+<xref linkend="ST_ReducePrecision"/>
+ </para>
</refsection>
</refentry>
@@ -221,11 +222,7 @@ Returns a geometry representing the shared portion of geometries A and B.
<para>ST_Intersection in conjunction with ST_Intersects is very useful for clipping geometries such as in bounding box, buffer, region
queries where you only want to return that portion of a geometry that sits in a country or region of interest.</para>
- <para>
- </para>
<note><para>Geography: For geography this is really a thin wrapper around the geometry implementation. It first determines the best SRID that
fits the bounding box of the 2 geography objects (if geography objects are within one half zone UTM but not same UTM will pick one of those) (favoring UTM or Lambert Azimuthal Equal Area (LAEA) north/south pole, and falling back on mercator in worst case scenario) and then intersection in that best fit planar spatial ref and retransforms back to WGS84 geography.</para></note>
@@ -298,7 +295,19 @@ from ST_GeomFromText('LINESTRING Z (2 2 6,1.5 1.5 7,1 1 8,0.5 0.5 8,0 0 10)') A
</refsection>
<refsection>
- <para><xref linkend="ST_3DIntersection" />, <xref linkend="ST_Difference"/>, <xref linkend="ST_Union"/>, <xref linkend="ST_Dimension"/>, <xref linkend="ST_Dump"/>, <xref linkend="ST_Force2D" />, <xref linkend="ST_SymDifference"/>, <xref linkend="ST_Intersects"/>, <xref linkend="ST_Multi"/></para>
+ <para>
+<xref linkend="ST_3DIntersection"/>,
+<xref linkend="ST_Difference"/>,
+<xref linkend="ST_ClipByBox2D"/>,
+<xref linkend="ST_Dimension"/>,
+<xref linkend="ST_Dump"/>,
+<xref linkend="ST_Force2D"/>,
+<xref linkend="ST_Intersects"/>,
+<xref linkend="ST_Multi"/>,
+ </para>
</refsection>
</refentry>
@@ -620,8 +629,10 @@ GEOMETRYCOLLECTION(
"miss" cases are faster to check as boxes for all parts typically cover smaller area than original geometry box,
"hit" cases are faster because recheck operates on less points.
<code>max_vertices</code> must be 5 or more, as 5 points are needed to represent a closed box.
- <code>gridSize</code> can be specified to have clipping work in fixed-precision space (requires GEOS-3.9.0+).
</para>
<para>Performed by the GEOS module.</para>
<para>Availability: 2.2.0</para>
<para>Enhanced: 2.5.0 reuses existing points on polygon split, vertex count is lowered from 8 to 5.</para>
@@ -699,10 +710,11 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
<para>
<xref linkend="ST_AsText" />,
-<xref linkend="ST_ClipByBox2D" />,
-<xref linkend="ST_Segmentize" />,
-<xref linkend="ST_Split" />,
-<xref linkend="ST_NPoints" />
+<xref linkend="ST_Segmentize"/>,
+<xref linkend="ST_Split"/>,
+<xref linkend="ST_NPoints"/>,
</para>
</refsection>
</refentry>
@@ -735,11 +747,7 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
It is called a symmetric difference because <code>ST_SymDifference(A,B) = ST_SymDifference(B,A)</code>.
</para>
- <para>
- </para>
@@ -817,7 +825,12 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
<refsection>
- <para><xref linkend="ST_Difference" />, <xref linkend="ST_Intersection" />, <xref linkend="ST_Union" /></para>
+ <para>
+ </para>
</refsection>
</refentry>
@@ -887,11 +900,7 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
url="http://blog.cleverelephant.ca/2009/01/must-faster-unions-in-postgis-14.html">http://blog.cleverelephant.ca/2009/01/must-faster-unions-in-postgis-14.html</ulink>
</para>
- <para>A <code>gridSize</code> can be specified to work in fixed-precision space.
- The inputs are snapped to a grid of the given size, and the result vertices are computed
- on that same grid.
- (Requires GEOS-3.9.0 or higher)
- </para>
<note><para><xref linkend="ST_Collect" /> may sometimes be used in place of ST_Union,
if the result is not required to be non-overlapping.
@@ -902,7 +911,7 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
<para>ST_Union creates MultiLineString and does not sew LineStrings into a single LineString.
Use <xref linkend="ST_LineMerge" /> to sew LineStrings.</para>
<para>NOTE: this function was formerly called GeomUnion(), which
was renamed from "Union" because UNION is an SQL reserved
word.</para>
@@ -992,7 +1001,8 @@ MULTILINESTRING((3 4,4 5),(1 2,3 4))
<xref linkend="ST_MemUnion" />,
- <xref linkend="ST_SymDifference" />
+ <xref linkend="ST_SymDifference" />,
+ <xref linkend="ST_ReducePrecision"/>
</para>
</refsection>
</refentry>
@@ -1040,11 +1050,7 @@ MULTILINESTRING((3 4,4 5),(1 2,3 4))
striking a balance between ST_Union and <xref linkend="ST_MemUnion" />.
</para>
- <para>
- </para>
<para>&Z_support; However, the result is computed using XY only.
The result Z values are copied, averaged or interpolated.</para>
@@ -1059,13 +1065,14 @@ on that same grid. (Requires GEOS-3.9.0 or higher)
<para>
- <xref linkend="ST_Union" />,
- <xref linkend="ST_MemUnion" />,
- <xref linkend="ST_Collect" />,
- <xref linkend="ST_Node" />
+ <xref linkend="ST_Union"/>,
+ <xref linkend="ST_MemUnion"/>,
+ <xref linkend="ST_MakeValid"/>,
+ <xref linkend="ST_Collect"/>,
+ <xref linkend="ST_Node"/>,
</para>
</refsection>
</refentry>
</sect1>
Summary of changes:
doc/postgis.xml | 7 ++++
doc/reference_overlay.xml | 87 +++++++++++++++++++++++++----------------------
2 files changed, 54 insertions(+), 40 deletions(-)
hooks/post-receive
