[PostGIS] #5886: snapping edge 1 to new node moves it past edge 2
trac at osgeo.org
Mon Apr 28 04:11:52 PDT 2025
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: topology | Version: 3.5.x
Resolution: | Keywords: robustness
Comment (by strk):
The problem at hand is that when we snap the existing edge (first line
entered in the topology) to the existing top vertex of edge 2, the edge is
moved enough to cross the other (bottom) vertex of edge 2.
A solution could be to FIRST snap edge 1 to the other vertex, which is
closer, but the current code ASSUMES the topology is never left in this
state of having vertices closer than topology tolerance to segments
without enforcing such characteristic.
So another solution would be to NEVER allow a topology to have segments at
closer-than-topology-precision distance from vertices that are not
endpoints of such segments. An experimental change in this direction is in
https://git.osgeo.org/gitea/postgis/postgis/pulls/243
For the sake of analysis it would be useful to include a location in
topological errors like the one triggered by this case (see #5889), and
would also be useful to have tools to check if a topology is in such
"unstable" state (see
https://trac.osgeo.org/postgis/ticket/5862#comment:16).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5886#comment:2>
